Heat Exchangers, Can they go? |
porschefile2010 |
May 10 2013, 12:45 PM
Member Group: Members Posts: 228 Joined: 26-May 11 From: Whangaparaoa, New Zealand Member No.: 13,118 Region Association: Australia and New Zealand |
Apart from the obvious loss of s heating system and demister are there any negatives to getting rid of heat exchangers?
Jeffs9146 |
May 10 2013, 01:10 PM
QUOTE demister (IMG:style_emoticons/default/confused24.gif) No you don't need them if you don't need heat! |
May 10 2013, 01:28 PM
Fresh air fan to clear a foggy windshield. Not something used all that often in disco bay, i presume? (IMG:style_emoticons/default/laugh.gif) |
Elliot Cannon |
May 10 2013, 01:44 PM
No heat in my car for nine years. Don't need it, don't miss it. Although I still have the fresh air fan to defog the windshield.
Cheers, Elliot |
Jeffs9146 |
May 10 2013, 02:19 PM
QUOTE Fresh air fan to clear a foggy windshield. Not something used all that often in disco bay, i presume? I should have guessed that is what it is called in New Zealand! (IMG:style_emoticons/default/monkeydance.gif) |
porschefile2010 |
May 10 2013, 05:16 PM
I suppose I was just concerned that without them there might be more heat getting around the sump and therefore raise the oil temparature. But the I guess there is enough air blowing past that area so as not to cause the problem???
Lo-Fi Version | Time is now: 17th May 2024 - 09:13 AM |
