2 Pages V < 1 2
> Group buy, door panel kit - fiberglass, vinyl and padding, $139 for a set in black- Tan, white or brown extra, assembly required
Mikey914
post May 14 2013, 02:23 AM
Post #21
The rubber man
QUOTE(bigkensteele @ May 13 2013, 07:10 PM) *
No early tan?
BTW, when is the blue plaid going to be ready? (IMG:style_emoticons/default/poke.gif)
Early tan is actually NLA --- for now, but I am working on that.
And yes I need to get back on the plaid project. I have made some progress and will have several others also. We have got it set up to make a presewn kit to insert the panels, but I need to drop some serious coin. Maybe before WCR?
r3dplanet
post May 14 2013, 11:16 AM
Post #22
I'm in for a set with early brick mold. Can pick up locally (IMG:style_emoticons/default/smile.gif)
porsche_dreamer
post May 14 2013, 06:26 PM
Post #23
Ill take an early brick set in black. Thanks
Harpo
post May 14 2013, 06:43 PM
Post #24
Mine has shipped already. Thanks Mark
spode
post May 15 2013, 09:30 AM
Post #25
I'm in for a set with early brick mold in black.
spode
post May 18 2013, 01:31 AM
Post #26
Panels arrived today. Thanks
Dasnowman
post May 18 2013, 01:52 AM
Post #27
You miss 100% of shots you don't take!
Would you just sell the F/G door panel? Was just thinking about painting the f/g and doing a pull strap instead or the door handle doing a track auto cross car trying to keep the weight down.
Harpo
post May 18 2013, 07:40 AM
Post #28
Good morning everyone,
To those of you that have already used the Mark's F/G door panels are you stapling or gluing this together?
Thanks
David
Mikey914
post May 18 2013, 10:36 AM
Post #29
The rubber man
I'd recommend glue. That's what we use.
Mikey914
post May 18 2013, 10:38 AM
Post #30
The rubber man
QUOTE(Dasnowman @ May 18 2013, 12:52 AM) *
Yep they are right here -
http://www.shop.914rubber.com/914-Fibergla...ls-914FG-DP.htm
Thx
jeeperjohn56
post May 18 2013, 02:30 PM
Post #31
Mark, what kind of glue did you use for your panels? and how do attache the top vinyl to the bottom basket weave? John (IMG:style_emoticons/default/confused24.gif)
Harpo
post May 18 2013, 03:21 PM
Post #32
I purchased medium strength 3M trim glue. Here is a link with the step by step procedures http://www.914world.com/bbs2/index.php?showtopic=54608.
However he only stapled and Mark is recommending gluing.
David
Harpo
post May 18 2013, 03:23 PM
Post #33
Mark are we gluing everything or just the edges?
David
3d914
post May 18 2013, 04:38 PM
Post #34
Mark, can you provide a couple of pics of your finished panels - and one pic installed with all hardware?
TIA
Mikey914
post May 18 2013, 08:17 PM
Post #35
The rubber man
QUOTE(3d914 @ May 18 2013, 03:38 PM) *
TIA
I glue the foam and edge glue the vinyl. I'm on the road til Tuesday but will post when I'm back. I did start throwing in the aluminum strip to secure the bolster no extra charge along with the pop rivets.
2 Pages V < 1 2
- Lo-Fi Version Time is now: 9th June 2026 - 12:28 AM
