Clutch Pedal Goes to the Floor, ...after a bunch of adjustments and running perfekt |
7TPorsh |
May 13 2013, 02:38 PM
Been spending a some time here and there over a couple of weeks to get my "always in need of adjustment" clutch cable set.
Kept loosening and tube and cable look good. Realized this weekend that a retainer was missing at the pulley end so the cable and its covering were slipping. I got that all fixed up and used a shorter barrel washer. I was driving the car in the hills and go for second gear and POP pedal go to the floor. Coasted downhill 2 miles home...love living in the hills. So I check under the car and there is still full tension on the cable. Pedal just flops. Next step I need to do I guess is pull the carpet again and take a look. I thought when the cable goes it would be loose...if the spring goes, the same. Pedal just flops. Any ideas? |
McMark |
May 13 2013, 02:47 PM
roll pin
xperu |
May 13 2013, 02:53 PM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
7TPorsh |
May 13 2013, 03:11 PM
spring or the rod from the pedal to the cable...
VaccaRabite |
May 13 2013, 03:27 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Yep. You sheared the roll pin.
7TPorsh |
May 13 2013, 03:33 PM
So expensive part; easy to fix?
or cheap part; hard to fix |
May 13 2013, 03:39 PM
it may have just fallen out.
Pull out the carpet, pull out the pedal board. Cable is on the ground, front of the tunnel, hard to see. Spring is on the pedal assembly. both are cheap, Rich |
Elliot Cannon |
May 13 2013, 03:58 PM
You can check with bdstone and see what he wants for a rebuilt pedal assembly or you can rebuild it yourself. http://www.pelicanparts.com/techarticles/M...dal_cluster.htm
partwerks |
May 13 2013, 08:11 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Make sure the cable is coming out straight from out of the firewall and not fraying the cable like mine did, thus snapping 2 clutch shafts till it was found out.
Haudiosolutions |
May 13 2013, 08:46 PM
Member Group: Members Posts: 215 Joined: 19-October 10 From: Sevierville, TN Member No.: 12,284 Region Association: South East States |
Gotta parrot the others and say roll pin. Had the same thing happen to me but with a very unhappy while getting sunburnt wife because we were supposed to be shopping for a car for her.... My pin was a BI*CH to get out but I don't have a press and I kept the cluster in the car. Drilled out the old one and hammer and punched in the new one. all has been well *with that* since then. I did replace the cable at the same time.
7TPorsh |
May 15 2013, 02:07 PM
7TPorsh |
May 15 2013, 02:08 PM
7TPorsh |
May 15 2013, 02:09 PM
I hate to ask but how is it supposed to look?
dlee6204 |
May 15 2013, 02:14 PM
dlee6204 |
May 15 2013, 02:15 PM
You'll probably want to invest in a new clutch pedal. That hole looks pretty ovaled.
brant |
May 15 2013, 02:22 PM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
nice!
sometimes I wonder what people are thinking recently I came across PO work on the rear brake connection to the parking brake cable one side had a nail in it.. the other a bolt and nut nice |
7TPorsh |
May 15 2013, 02:25 PM
Does the pedal slide off or do I need to dismantle the cluster?
This sux |
7TPorsh |
May 15 2013, 02:26 PM
Probably need to take it all apart and see what other handywork is there.
dlee6204 |
May 15 2013, 02:28 PM
The pedal should just rotate off now that the "pin" is broken.
brant |
May 15 2013, 02:29 PM
yes pull the whole cluster and rebuild it.
it looks like it needs it put the bushing kit into the rebuild of the cluster. when my roll pin sheared 20 years ago, it too ovaled the hole in that pedal shaft. you can drill the hole bigger but at the risk of weaking the shaft... but you have to do something to address the ovaled hole or the pedal will have slop in it. I replaced mine when it happend to me, but you won't know if you have to until you pull the cluster apart and examine. |
Lo-Fi Version | Time is now: 18th May 2024 - 05:38 AM |
