Clutch Pedal Goes to the Floor, ...after a bunch of adjustments and running perfekt |
May 20 2013, 04:13 PM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The rest of the cluster looks ok. Did the factory use brass bushings? How does it come apart? The factory used plastic bushings. Yours has been apart before. That pedal arm is f***ed. Find another one. The cluster comes apart when you push the shafts out of it. I'd be looking around on the classifieds for a used cluster. I don't think I would trust yours. --DD |
McMark |
May 20 2013, 11:41 PM
I feel bolts are the wrong material/design for this application in pretty much any form. If the section of bolt that passes through the arm is threaded, those threads can deform and begin a wobble that will only get worse with time. The only setup that I would feel even remotely comfortable with would a bolt that has a shoulder that would carry the side loads, like the one below. A standard bolt isn't hard enough either. I would want a 12.9 bolt it I were going to even think about something like that.
(IMG:http://www.914world.com/bbs2/uploads_offsite/img.directindustry.com-419-1369114868.1.jpg) The reason the roll pin was used was because it allows for an interference fit that won't come loose with heat or wear. It's also multiple layers of hardened spring steel, so it won't shear. That little piece of metal is taking a LOT of load. |
Lo-Fi Version | Time is now: 9th June 2024 - 12:12 PM |
