| Neil_J |
May 16 2013, 07:37 AM
Newbie ![]() Group: Members Posts: 1 Joined: 7-June 04 From: Pacifica, CA Member No.: 2,167 |
Some parts are new upgrades never installed, others are from a well maintained 914 always garaged in California, now being converted to an 8. Location of parts are indicated by CA (San Francisco bay area) or NV (Las Vegas).
CA parts may be picked up locally or shipped FOB within the U.S. Since this ad was posted on 3 forums there was a change in availability of NV parts. Originally, NV parts were to be shipped from Nevada but that became logistically difficult so those parts will be brought back to CA sometime in July and picked up or shipped from there. I will do my best to supply additional info for requested items. Parts will be held in the date stamp order of replies posted to ads in 3 forums. Ads will be updated with the current #1 positions. Used items sold "as is". PM for additional info. Payment by cash, cashier's check or +3% for Paypal. Rare 911 on-engine oil cooler modified for 914-6 conversions (right angle outlet allows hard oil lines to clear suspension) - good condition NV $400 Custom set of red Magnacor 8.5mm plug and ignition wires for Porsche flat 6 single plug engines - Used, good condition NV $100 MSD 6A unit - used, good condition NV $100 914-6 Oil Hose Line - Oil tank body shell to oil cooler hose line - Flexible center with metal formed ends 6k mi NV $40 914-6 Oil Hose Line - Tank to interface hard oil return pipe on engine - Flexible Line with Female M30 ends. 6k mi NV $25 Bursch 1 3/4" 2 in 1 out muffler with chrome tip 2k mi CA $200 914 Relay Board - Rebuilt and upgraded by Brad Mayeur - New unused CA $175 914 Blower Fan new unused CA $150 PARTS BEING HELD: HELD FOR Goodbars (Pelican) 914-6 OEM oil tank with filler neck, cap, dipstick & filter console - 5k miles NV $900 HELD FOR David McLaughlin (Pelican) 914-6 fiberglass rear valence with hole for exhaust NV $100 HELD FOR Mr242 911 OEM 911 CUP air Intake with shortened snorkel and K&N filter (breathes great, quieter than water shields, allows for conversation in 914 cab) NV $100 HELD FOR carr914 914-6 complete fiberglass engine compartment "sheet metal" NV $80 HELD FOR Luke M KEP 9" 228mm clutch with 1500 lb pressure plate & custom flywheel: 5k miles NV $350 HELD FOR 1Trick6 used OEM 911 high torque starter motor (good match for 911 3.0L & 901 trans) NV $80 HELD FOR Luke M Exhaust hanger - used, good condition NV $20 HELD FOR carr914 Modified 2 in 1 out 911 muffler, matches 914-6 valence outlet hole - used good condition NV $100 HELD FOR scrz914 Carrera C-2/4 front oil cooler with manually switchable fan (temp switch defeated) NV $200 HELD FOR scrz914 Mocal OT/2 remote oil cooler thermostat for 12 AN fittings NV $80 HELD FOR Goldbars (Pelican) pair of 914 axles (8 k mi) with 4 CVs 4k mi $150 HELD FOR Luke M 914-6 Accelerator rod NV $80 HELD FOR Luke M 914-6 Throttle bell crank NV $50 HELD FOR Brant MSD Blaster coil - used, good condition NV $15 ![]() ![]() ![]() ![]() ![]() |
Neil_J FS 914-6 Conversion & 914 Parts May 16 2013, 07:37 AM
Luke M Consider these items sold but need more info/pics.... May 16 2013, 07:50 AM
Neil_J Please hang on.. My wife had a run-in tonight wit... May 17 2013, 05:12 AM
carr914 I would like the Fiberglass Engine "Sheet Met... May 16 2013, 08:22 AM
brant 2nd in line for the fiberglass engine tin please May 16 2013, 09:00 AM
McMark I'll take those headers. Sending a PM now. May 16 2013, 09:32 AM
Neil_J
... May 17 2013, 07:50 AM
1TRICK6 PM sent on starter motor. May 16 2013, 10:13 AM
Cool914 I will take the bell crank if it is for a non 914-... May 16 2013, 12:00 PM
Vysoc PM sent on Quick 6 Engine Mount.
Vysoc May 16 2013, 01:58 PM
shawn914 PM sent on 3.0 and RJohnson motor mount/kit May 16 2013, 04:51 PM
Daiberl PM sent on carbs. May 16 2013, 07:02 PM
scrz914 sending pm on oil cooler and MoCal thermostat May 16 2013, 09:17 PM
carr914 Did you get my pm? May 17 2013, 05:16 AM
Mr.242 Interested:
911 OEM 911 CUP air Intake with shorte... May 19 2013, 11:21 AM
Neil_J Update
SOLD - headers, springs and new oil lines.... May 27 2013, 06:16 PM
brant Neil,
I could use the blaster coil
I "thin... May 27 2013, 07:14 PM
Neil_J You are 1st in line for the coil and fiberglass en... May 27 2013, 07:43 PM
Neil_J Brant,
There was a PM miscommunication with anoth... May 28 2013, 06:28 PM
carr914
HELD FOR brant 914-6 complete fiberglass engine ... May 27 2013, 08:19 PM
Neil_J T.C. My apologies. I thought you meant you were ... May 27 2013, 09:17 PM
carr914 Neil, I believe I wrote in the pm (I delete my pm... May 28 2013, 04:48 AM
Neil_J You are back at 1st for the FG engine "metal... May 28 2013, 05:27 AM
brant no problem at all! May 28 2013, 06:30 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 08:20 AM |
