| LotusJoe |
May 16 2013, 06:44 PM
Europa Twink Driver ![]() ![]() Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
I am experiencing wheel wobble at freeway speeds. At around 60 the steering wheel wobbles, but you can drive through it. At about 70 it quits. I assumed it was a tire out of balance. So I rotated the the backs to the front. No difference. I then put a different set of tires on the car. Same issue. Then I switched yet another set of tires from the race car. Same issue. Unless I have 4 sets of tires that are out of balance I'm a bit perplexed. The entire front end has completely new everything. Any thoughts on where to check? (IMG:style_emoticons/default/confused24.gif)
New: FreeMotion roller bearings on the arms Bilstein Sport Shocks Turbo Tie rods New tie rod ends New lower ball joints New upper polly bushings New wheel bearings New Rotors New Calipers New bushings on the sway bar (Everything is new) |
| JawjaPorsche |
May 16 2013, 06:49 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
I assume you had the front end aligned after putting all those parts on? Just asking. (IMG:style_emoticons/default/biggrin.gif)
| LotusJoe |
May 16 2013, 06:50 PM
| JawjaPorsche |
May 16 2013, 06:53 PM
I assume you had the front end aligned after putting all those parts on? Just asking. Yes Crap, you are not making this easy to figure out. (IMG:style_emoticons/default/biggrin.gif) |
| 914itis |
May 16 2013, 06:54 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
Get all four balanced by a good tire shop and you will be good to go.
| Elliot Cannon |
May 16 2013, 06:56 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
Adjust the front wheel bearings. Sounds like they are loose.
| 76-914 |
May 16 2013, 07:10 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,896 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
| Jeffs9146 |
May 16 2013, 07:28 PM
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Letting the car sit to long on your tires, maybe you have flat spots!
| Bartlett 914 |
May 16 2013, 07:34 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
| SirAndy |
May 16 2013, 07:35 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,483 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Rubber steering coupler condition? That usually doesn't translate into vibrations at certain speeds but rather the car "darting" left or right on its own. But it can't hurt to check ... Do you have wheel spacers? One thing that i have noticed is that if the wheel spacers aren't 100% clean, they will act as if the wheel isn't balanced and give you vibrations at certain speeds. (IMG:style_emoticons/default/idea.gif) |
| r_towle |
May 16 2013, 07:58 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Steering rack?
| worn |
May 16 2013, 09:01 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,607 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
I am experiencing wheel wobble at freeway speeds. At around 60 the steering wheel wobbles, but you can drive through it. At about 70 it quits. I assumed it was a tire out of balance. So I rotated the the backs to the front. No difference. I then put a different set of tires on the car. Same issue. Then I switched yet another set of tires from the race car. Same issue. Unless I have 4 sets of tires that are out of balance I'm a bit perplexed. The entire front end has completely new everything. Any thoughts on where to check? (IMG:style_emoticons/default/confused24.gif) New: FreeMotion roller bearings on the arms Bilstein Sport Shocks Turbo Tie rods New tie rod ends New lower ball joints New upper polly bushings New wheel bearings New Rotors New Calipers New bushings on the sway bar (Everything is new) On my 911 this turned out to be a form of bump steer cured by an elephant racing product. The car had been very lowered by a po. You don't mention ride height, so this is another thought. |
| tomeric914 |
May 16 2013, 09:55 PM
One Lap of America in a 914! ![]() ![]() ![]() Group: Members Posts: 1,324 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States
Tighten the wheel bearings and then tighten them a little more than you would like. This assuming that they are in good condition and well greased to begin with.
| GaroldShaffer |
May 16 2013, 10:01 PM
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,648 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None
Tighten the wheel bearings and then tighten them a little more than you would like. This assuming that they are in good condition and well greased to begin with. (IMG:style_emoticons/default/agree.gif) |
| Cap'n Krusty |
May 16 2013, 11:10 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
I am experiencing wheel wobble at freeway speeds. At around 60 the steering wheel wobbles, but you can drive through it. At about 70 it quits. I assumed it was a tire out of balance. So I rotated the the backs to the front. No difference. I then put a different set of tires on the car. Same issue. Then I switched yet another set of tires from the race car. Same issue. Unless I have 4 sets of tires that are out of balance I'm a bit perplexed. The entire front end has completely new everything. Any thoughts on where to check? (IMG:style_emoticons/default/confused24.gif) New: FreeMotion roller bearings on the arms Bilstein Sport Shocks Turbo Tie rods New tie rod ends New lower ball joints New upper polly bushings New wheel bearings New Rotors New Calipers New bushings on the sway bar (Everything is new) Well, first thing we need so we can help you is the production date of your car. 914s built after late '72 have hubcentric wheel mounting, earlier cars use the lug bolts to center the wheels. If you have the wrong wheels on the car, you'll have balance problems. Make sure the tires are round, and that the wheels are balanced on both the inner and outer planes. If those things don't help, come back for more. BTW, rear wheel balance can, in some instances, mimic front wheel balance on cars with this kind of suspension. Good luck! The Cap'n |
| L-Jet914 |
May 17 2013, 12:02 AM
Member ![]() ![]() Group: Members Posts: 404 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
I am having the same issues as Lotus. Now off to check all the fore mentioned items (IMG:style_emoticons/default/biggrin.gif)
| GeorgeRud |
May 17 2013, 07:08 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Kind of a long shot, but you could also consider having the tires trued (shaved) to be sure they are actually round when mounted on your rims. However, not many tire stores still offer that service.
| Steve Snyder |
May 17 2013, 08:35 AM
Member ![]() ![]() Group: Members Posts: 241 Joined: 10-June 08 From: Graham, NC Member No.: 9,158 Region Association: South East States |
You might also want to ensure the four Allen bolts on your steering column dash bracket are nice and tight.
| brant |
May 17 2013, 08:37 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,211 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
not a solution to your problem
but I don't like tight wheel bearings I've seen tight wheel bearings fail at the track when everything gets hot and expands. and I've seen them weld to the spindle, destroying the spindle when they fail... if your using your brakes or creating lots of wheel heat then tight wheel bearings are your enemy on a caually driven street car I'm sure they won't cause harm. plus a gradual failure can be identified in the annual repacking brant |
| 6freak |
May 17 2013, 08:47 AM
MR.C ![]() ![]() ![]() ![]() Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
Adjust the front wheel bearings. Sounds like they are loose. BINGO (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 15th June 2026 - 03:10 AM |
