rear calipers |
rear calipers |
marks914 |
Nov 27 2004, 07:07 AM
Senior Member Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
I am trying to get my rear calipers rebuilt on my early 72. The prices are outrageous ($170 per caliper!) does anyone konw if any year rear caliper will work? I also have heard that front calipers will work on the rear (no e-brake though). does it have to be an early caliper or late?
I am in the middle of switching to five lug. Heres the situation: I have SC front struts/ brakes. I could remove the BMW 320 calpiers on the fronts now and put them on the rear. I would like to go stock in the rear but over $300 for calipers, thats crazy. How difficult is it to rebuild the rear calipers? Thanks All Mark |
Joe Ricard |
Nov 27 2004, 07:25 AM
Rebuild is fairly straight forward. Just a few things you need to be aware of in the adjustment screws for venting. I always look in the book to get it straight. Pistons don't just pop out like the fronts. the screw out and if memory serves it is backwards thread.
Then it is just a few seals and put them back together. Once you have done this setting venting clearance makes more sense. 2nd yes you can put stock 914/4 front on the back and yes that takes away your parking brake. The difference is 1/8 inch to get the caliper cenered on the rotor if you use a late caliper. Early calipers bolt right on. This is up to you and if done wrong you could die or kill someone else. Brake bias is essential and critical. You really don't want to over brake the rears. |
anderssj |
Nov 27 2004, 07:59 AM
Dog is my copilot... Group: Members Posts: 1,654 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
Hi Mark,
I'm just finishing up a rebuild on one of my rear calipers (also a 72, but I think all years are the same). Got the re-build kit from AA (not a plug--but they were the only ones that had the o-rings for the adjusters). Not too bad a job--I've got a copy of an old issue of European Car that gives step-by-step instructions with pictures. I'll try to scan a copy, and will let you know here if it works. Best, Steve A- |
davep |
Nov 27 2004, 08:02 AM
914 Historian Group: Benefactors Posts: 5,138 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I have rebuilt about 20 rear calipers over the years. They can be a real bitch to do. Getting them apart can be difficult. Getting any parts is very expensive; have you looked at the prices of the kits available? I usually figure about 5 hours to rebuild one. For many years I have charged $150 exchange for the rears ( and $50 for the fronts). I don't know if I can keep it at that level much longer. So far I have been able to reuse pistons, however there are two varieties and my stock of good pistons is running low. If I have to start buying pistons, you can imagine the price will go up dramatically. The adjuster gear that is often missing is also unobtainable. If the cores come with the adjusters, they go out with them. If not, they only get one. These will not last forever either.
I look on brakes as cheap insurance. As Joe says, it could be your funeral, or someone elses. Brake swapping is very popular, but you have to build it as a balanced system. You can't just throw on whatever you have. The 914 is very sensitive, and you can spin in the blink of an eye. That is the reason for the proportioning valve in the 914 design in the first place. The factory tuned the system with that valve. You can be sure a lot of engineering and testing went into it. If they could have cut the cost of the valve, you can be sure they would have since the car cost the factory far too much in the first place. |
jim912928 |
Nov 27 2004, 08:27 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
I just finished rebuilding my rears....including the o-rings for the brake adjusters. Got my kits from Dave at GPR. They were not that expensive. You have to ask for not only the brake rebuild kit..but the o-rings also (sold them separate).
Hardest part of rebuilding the rings is getting the internal c-clip in out. First one I tried using the screwdrivers trick as outlined in the PP bulletin. Forget that it's frustrating as all get out. I went down and got a inner/outer c-clip tool and made the job alot easier. Brakes are like new now! It's not difficult, just time consuming. |
ws91420 |
Nov 27 2004, 09:29 AM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
Check your local FLAPS. A-1 cardone a remanufacter does the rear calipers. When I got mine they were around $100 exchange. Advance in Warren can get em.See this link
Rhodes71/914 |
Nov 27 2004, 11:17 AM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
Searched on the site mentioned above, can someone tell my what loaded vs unloaded means.
thx |
Part Pricer |
Nov 27 2004, 11:56 AM
Believe everything I post Group: Benefactors Posts: 1,825 Joined: 28-December 02 From: Danbury, CT Member No.: 35 |
Loaded includes all hardware and brakes pads.
marks914 |
Nov 27 2004, 04:50 PM
Thanks
For 100 bucks with the hardware and pads, its worth it. Mark |
ws91420 |
Nov 27 2004, 09:19 PM
Does not include pads or hardware. Also need to switch brake cable arm off old caliper but still worth it. At least when I got mine 3 yrs ago.
McMark |
Nov 28 2004, 02:07 AM
Great step by step. Ferrari 308s had nearly identical calipers on them. The only difference you'll notice is the spacers that go in between the caliper halves to fit a thicker rotor.
308 Caliper Rebuild |
Lo-Fi Version | Time is now: 5th May 2024 - 08:40 AM |
