| Axel |
May 23 2013, 01:31 PM
Newbie ![]() Group: Members Posts: 17 Joined: 15-May 13 From: Lenexa, Kansas Member No.: 15,875 Region Association: Upper MidWest |
I had this exact same issue in my 74 2.0 for 10 years. Numerous mechanics looked at it and were unable to figure out what was going on. I finally took it down to Brad Mayeur and he tried unplugging Temp Sensor #2. For some reason that completely resolved the bucking at 4k rpm. It's worth noting that I have a Petronix installed, so it definitely wasn't the points/condenser. Thanks, I'll give it a shot. Thanks to all for your input. After changing everything out without it having any effect, I checked the wiring for both temperature sensors. Nothing seemed out of place, but after checking these wires, the stuttering and bucking seem to have gone away. (IMG:style_emoticons/default/confused24.gif) |
| TheCabinetmaker |
May 23 2013, 01:47 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,377 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Well that's great. If it comes back, you now know where to look.
| gunny |
May 23 2013, 07:22 PM
Member ![]() ![]() Group: Members Posts: 205 Joined: 17-October 12 From: Madison Al Member No.: 15,051 Region Association: South East States |
Which sensor is #2? I have the same issue.
| Axel |
May 24 2013, 10:00 AM
Which sensor is #2? I have the same issue. I don't know which it was. I moved both wires a while I was examining them. I couldn't find any problems with either one, but the physical manipulation of them seemed to fix the stuttering. I must have a short in one of them. |
| TheCabinetmaker |
May 24 2013, 02:46 PM
temp sensor # 2 is the head temp. Only has one wire. #1 is the intake air temp. The one in the plenum, next to the tps on a 2.0L. It has two wires. The thermo tine switch, which senses ambient air temp, has one wire. It tells the ecu if its cold enough to turn on the cold start valve. Its mounted below the plenum on the bracket that bolts the plenum to the case. Its on the passenger side.
Lo-Fi Version | Time is now: 9th June 2026 - 12:12 AM |
