Shifting issue |
Shifting issue |
rmital |
May 21 2013, 08:43 AM
Northeast optimist Group: Members Posts: 1,946 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
I got an email from a local 914 owner today asking about his shifting situation.
Sounds like this problem happened all of a sudden..... ....his description: "the pedal has plenty of give back but unable to find the gears. First gear position drops the stick as if it's going to touch the center console, and still remains in neutral. Able to get it into 2nd gear every once in a while but that's about it". could be a simple cone screw gone???? or clutch tube??? with the shifter almost "touching" the center console, I would assume cone screw failure? your thoughts???? (IMG:style_emoticons/default/confused24.gif) |
Cap'n Krusty |
May 21 2013, 08:50 AM
It's impossible to give you a simple answer without knowing which shifter setup is used in the car. Tail shifters have no cone screws. In the vagueness of the description of the problem, the clutch could be an issue, or the roll pin in the pedal. The shifter "dropping" could mean the bushings in the shifter itself could have failed, or the spring.
The Cap'n |
rmital |
May 21 2013, 08:54 AM
It's impossible to give you a simple answer without knowing which shifter setup is used in the car. Tail shifters have no cone screws. In the vagueness of the description of the problem, the clutch could be an issue, or the roll pin in the pedal. The shifter "dropping" could mean the bushings in the shifter itself could have failed, or the spring. The Cap'n 75 2.0L / side shifter. |
914itis |
May 21 2013, 09:24 AM
Sounds like the bolt on the shift lever is loose or come screw.
rmital |
May 21 2013, 09:54 AM
914itis |
May 21 2013, 10:57 AM
If its easier to get it to me, I can help him out. My zip is 11412
rmital |
May 21 2013, 11:39 AM
Dr Evil |
May 22 2013, 08:53 AM
Pinch bolt on inner shift rod in center tunnel sounds loose, under the shifter. Side to side may be maintained, but fore and aft will be lost with excessive stick throw.
914itis |
Jun 6 2013, 08:49 PM
He stopped by today and this is what I found.
Notice the rod resting op top. His cone screw was sitting on the plastic cover. He's a happy Camper. |
rgalla9146 |
Jun 6 2013, 09:03 PM
Advanced Member Group: Members Posts: 4,550 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
He stopped by today and this is what I found. Notice the rod resting op top. His cone screw was sitting on the plastic cover. He's a happy Camper. Excellent ! Saved him time and a NY tow job. Last I heard it was stuck in gear with a " difficult " to move lever. Could have been anything but proved to be the best thing. |
914itis |
Jun 6 2013, 09:06 PM
He stopped by today and this is what I found. Notice the rod resting op top. His cone screw was sitting on the plastic cover. He's a happy Camper. Excellent ! Saved him time and a NY tow job. Last I heard it was stuck in gear with a " difficult " to move lever. Could have been anything but proved to be the best thing. I learned from the best (IMG:style_emoticons/default/beerchug.gif) |
rick 918-S |
Jun 6 2013, 09:41 PM
Hey nice rack! -Celette Group: Members Posts: 20,444 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Make sure he installs a new cone screw ASAP. It has a plastic wade that acts as locktite to hold it in. It likely came loose because someone reused it and it no longer had the holding power. I've had mine loosen up before.
naro914 |
Jun 7 2013, 08:06 AM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
I just put a dab of loctite on my old ones...
76-914 |
Jun 7 2013, 08:18 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,495 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
rgalla9146 |
Jun 7 2013, 04:14 PM
He stopped by today and this is what I found. Notice the rod resting op top. His cone screw was sitting on the plastic cover. He's a happy Camper. Excellent ! Saved him time and a NY tow job. Last I heard it was stuck in gear with a " difficult " to move lever. Could have been anything but proved to be the best thing. Hey Paul I just went back and read this thread again.....I can't believe you picked it off in your first response ! Outstanding ! |
rgalla9146 |
Jun 7 2013, 04:23 PM
I got an email from a local 914 owner today asking about his shifting situation. Sounds like this problem happened all of a sudden..... ....his description: "the pedal has plenty of give back but unable to find the gears. First gear position drops the stick as if it's going to touch the center console, and still remains in neutral. Able to get it into 2nd gear every once in a while but that's about it". could be a simple cone screw gone???? or clutch tube??? with the shifter almost "touching" the center console, I would assume cone screw failure? your thoughts???? (IMG:style_emoticons/default/confused24.gif) Hey Ray You are friggin genius. You and Paul must use the same crystal ball. |
914itis |
Jun 7 2013, 04:37 PM
He stopped by today and this is what I found. Notice the rod resting op top. His cone screw was sitting on the plastic cover. He's a happy Camper. Excellent ! Saved him time and a NY tow job. Last I heard it was stuck in gear with a " difficult " to move lever. Could have been anything but proved to be the best thing. Hey Paul I just went back and read this thread again.....I can't believe you picked it off in your first response ! Outstanding ! Thanks Rory, |
914itis |
Jun 7 2013, 04:39 PM
Make sure he installs a new cone screw ASAP. It has a plastic wade that acts as locktite to hold it in. It likely came loose because someone reused it and it no longer had the holding power. I've had mine loosen up before. New cone screw was used with thead locker. I don't think it's going anywhere anytime soon. |
Lo-Fi Version | Time is now: 9th May 2024 - 12:30 PM |
