offset versus scrub radius |
r_towle |
May 23 2013, 12:41 PM
Custom Member Group: Members Posts: 24,576 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Does it make a difference what the offset is on a wheel with regards to scrub radius?
It does not seem that it would, given the stock suspension, no custom struts etc. Aside from that, what is the reason (aside from cost and availability) for using large spacers versus getting wheels that mount up with no spacer, yet are wide for flared cars? rich |
J P Stein |
May 24 2013, 07:32 AM
The following sketch does not represent all of the aspects of SR vs its effects....but the best I got.
It does show the method of measuring SR and one fella's attempt to fix it thru camber changes An increase in SR does indeed effect the car & handling, basically one increases the leverarm of the axle against rotation....leading to increased steering effort....that's the easy part to figure out. The increase also puts the CL of the tire/wheel farther fom the center of rotation.This gets this center "out ahead"of the rotation when turning....not a problem for minor (say 5-10 deg) steering inputs. Major inputs , such as found at AX, are another story. These will cause the tire to "shuffle" sideways rather than roll. ....been down this road with 10 inch wide front wheels...giving me about 2.5+ inches of SR.....resulting in an increable PUSH. Fixed it with 8 inch wide wheels but with only a .5 inch loss in tire width. Attached image(s) |
Matt Romanowski |
May 25 2013, 09:55 AM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
The following sketch does not represent all of the aspects of SR vs its effects....but the best I got. It does show the method of measuring SR and one fella's attempt to fix it thru camber changes An increase in SR does indeed effect the car & handling, basically one increases the leverarm of the axle against rotation....leading to increased steering effort....that's the easy part to figure out. The increase also puts the CL of the tire/wheel farther fom the center of rotation.This gets this center "out ahead"of the rotation when turning....not a problem for minor (say 5-10 deg) steering inputs. Major inputs , such as found at AX, are another story. These will cause the tire to "shuffle" sideways rather than roll. ....been down this road with 10 inch wide front wheels...giving me about 2.5+ inches of SR.....resulting in an increable PUSH. Fixed it with 8 inch wide wheels but with only a .5 inch loss in tire width. That diagram has nothing to do with camber. The guy is changing the strut to spindle angle, which changes the scrub radius. Changing just the camber of the wheel has no affect on scrub radius. |
J P Stein |
May 26 2013, 07:09 AM
That diagram has nothing to do with camber. The guy is changing the strut to spindle angle, which changes the scrub radius. Changing just the camber of the wheel has no affect on scrub radius. Gee, I left out some context on the sketch. That will almost always get a rise from some expurt. The author(?) of the sketch changed his strut angle to increase the *obtainable* negative camber on his 911. The mod had the effect on SR also....two good reasons to do the mod. The downside is the slug (or extra seam) in the A arm...I'm agin' it..do I have to explain the term "slug" + the whys & wherefores? I too modded my A arms but only to increase strength in the area I'd seen them break. |
Lo-Fi Version | Time is now: 20th May 2024 - 06:35 AM |
