offset versus scrub radius |
r_towle |
May 23 2013, 12:41 PM
Custom Member Group: Members Posts: 24,576 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Does it make a difference what the offset is on a wheel with regards to scrub radius?
It does not seem that it would, given the stock suspension, no custom struts etc. Aside from that, what is the reason (aside from cost and availability) for using large spacers versus getting wheels that mount up with no spacer, yet are wide for flared cars? rich |
andys |
May 27 2013, 02:10 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
Slight hijack, but since we're talking scrub raduis I though it might be best to ask here while everyone is still motivated :-) On my LS1 conversion car, I'm running 205-50-17 fronts with about 1/4" - 5/16" scrub; I think, if memory serves me correctly, I have 4 degrees caster. Since, IMO, my car steers like a dang truck, will taking out that scrub radius and going to zero have any significant effect on steering effort?
Thanks, Andys |
byndbad914 |
May 31 2013, 04:55 PM
shoehorn and some butter - it fits Group: Members Posts: 1,547 Joined: 23-January 06 From: Broomfield, CO Member No.: 5,463 Region Association: None |
...will taking out that scrub radius and going to zero have any significant effect on steering effort? Speaking from understanding and not actual experience so apply the appropriate amount of salt here, back in the 70s car mfrs put zero scrub into some large, land yacht car designs and the feedback was there was no feedback - the car was completely neutral at the steering wheel and therefore people would be wandering around the lane trying to keep the car moving straight. So, it is my understanding you do not want zero scrub, but a little offset inboard on a car like ours and the images JP attached above. Some modern cars have the offset outboard of the wheel centerline but I have heard that is not best for old tech vehicles and may have had something to do with working well with ABS but don't quote me on that. And again, no experience with that type of scrub. Scrub is not a bad thing when, like all things, it is used in moderation. One of the main things scrub will do is heat the tires up, so on circle track cars, we used to futz with the scrub both left and right (we would run two different scrub amounts since we only turned left) at each and every track to get the tire temps to be optimal. Too much scrub will just cook tires and build your forearms into an impressive, Popeye-like shape (IMG:style_emoticons/default/smile.gif) Too little was also not optimal. I am trying to recall if we ever were able to get to zero scrub, been a long time now, but I don't think so, I think it was always some "positive" (inboard) amount. |
Lo-Fi Version | Time is now: 20th May 2024 - 06:02 AM |
