| Krieger |
May 24 2013, 09:40 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,860 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
Directions say fuel level between top two lines. Why are there four lines? Or is it supposed to be set in the middle area between the two pairs of lines? Is idle speed sufficient?
| Krieger |
May 24 2013, 09:44 AM
Ahh! I did rotate it before I posted. I think it's too late. Sorry.
| J P Stein |
May 24 2013, 09:51 AM
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
The meniscus is supposed to go within the upper 2 lines, IMO.
I never had the guts to have the motor running.....too risky when working alone I set them with the fuel pressure ON, engine OFF.....worked out OK. |
| mskala |
May 24 2013, 10:12 AM
R ![]() ![]() ![]() Group: Members Posts: 1,949 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None
Yes top 2 lines, and the motor must be running.
| Krieger |
May 24 2013, 10:27 AM
Thanks Mark, it just seems like such a narrow range.
| mskala |
May 24 2013, 11:03 AM
Thanks Mark, it just seems like such a narrow range. I am not the expert but according to them expert guys the float level is a critical item and should be set near the beginning of the million things that must be set on weber-equipped cars. Luckily it tends to stay there once you set it. |
| Krieger |
May 24 2013, 12:50 PM
Great info! Thank you
Lo-Fi Version | Time is now: 9th June 2026 - 12:09 AM |
