| loco914 |
May 24 2013, 11:44 PM
Thy wheels have left the rail... ![]() Group: Members Posts: 47 Joined: 1-April 10 From: Amarillo, TX Member No.: 11,542 Region Association: None |
New transmission mounts and clutch cable installed tonight. Amazing how much better it shifts. (IMG:style_emoticons/default/driving.gif) Old mounts were badly cracked, replaced with stock mounts from Zim's. Worst part about the clutch cable was cramming myself under the dash to remove and reattach the clevis fork. Not a good time for a shoulder cramp! No matter how quickly you try to sit up, the steering wheel will not move.... (IMG:style_emoticons/default/blink.gif)
| TravisNeff |
May 25 2013, 12:50 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region
Its amazing what the little things can do!
| 914Sixer |
May 25 2013, 06:29 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,492 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Be sure and check your engine mounts, chances are they are not in good shape. They both seem to seem to fail about the same time.
| 914Sixer |
May 25 2013, 06:30 AM
| Elliot Cannon |
May 25 2013, 11:08 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
New transmission mounts and clutch cable installed tonight. Amazing how much better it shifts. (IMG:style_emoticons/default/driving.gif) Old mounts were badly cracked, replaced with stock mounts from Zim's. Worst part about the clutch cable was cramming myself under the dash to remove and reattach the clevis fork. Not a good time for a shoulder cramp! No matter how quickly you try to sit up, the steering wheel will not move.... (IMG:style_emoticons/default/blink.gif) I always remove the drivers seat and the steering wheel when I do that job. Takes a little longer but no shoulder cramps. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 9th June 2026 - 12:09 AM |
