914-6 build up |
914-6 build up |
trcarrera |
Nov 28 2004, 11:25 PM
Newbie Group: Members Posts: 14 Joined: 10-May 04 From: Granville, Ohio Member No.: 2,050 |
Im building a 914-6 and i want these parts I found these parts on Pelican Parts can any one tell me if I can get them for less
Part Number: SB-1100 Price: $359.65 Qty: 1 Description: Weltmeister 22mm Front Sway Bar Kit, includes the sway bar, bushings, adjustment slider clamps, adjustable drop links, hardware, and a complete instruction guide, 911/912 (1965-89), 914 All Part Number: SB-1900 Price: $26.80 Qty: 1 Description: Weltmeister U-tab kit Part Number: SB-1955 Price: $27.05 Qty: 1 Description: Weltmesiter front triangle mount adapter kit (requires gas tank removal) Part Number: TTK-930 Price: $147.50 Qty: 1 Description: 911 Turbo Tie Rod Kit 911/912/912E (1969-89), 914 All Part Number: ERMP-2011000 Price: $304.45 Qty: 1 Description: Elephant Racing Front Monoball Cartridge Set, 911/930 1965-89, 914 All Part Number: PEL-BSK-070 Price: $14.45 Qty: 1 Description: Bump Steer Kit 911/911 Turbo (1974-89) 914 (1973-76) Part Number: K-059-065-00 Price: $7.10 Qty: 2 Description: Front Outer Wheel Bearing, 911 (1965-89), 914-6, 924S All, 944/944 Turbo thru 86 Part Number: K-059-098-00 Price: $11.20 Qty: 2 Description: Front Wheel Bearing, Inner, 924S All, 944/944 Turbo thru 86, 911/912 (1965-89), 914-6 Part Number: PEL-9146-002 Price: $525.00 Qty: 1 Description: Improved 914-6 Bulkhead Motor Mount, with Hardware Kit, need pulley cover as a core Part Number: PEL-PW-CMM1 Price: $78.25 Qty: 1 Description: Competition Motor/Transmission Mount Set, pair Part Number: 194-3911R Price: $1569.75 Qty: 1 Description: Brembo Monoblock Brake Kit - Front - Porsche 911, S, SC, Carrera (1974-89), 11.1 inch Drilled Rotors Part Number: C-355-012-02 Price: $170.65 Qty: 1 Description: Master Cylinder, 19mm, 911/912 (1968-76), 914-6 (1970-72), 914 19mm Upgrade. Comes with grommets for feed lines |
Root_Werks |
Nov 29 2004, 12:58 PM
Village Idiot Group: Members Posts: 8,315 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
That is a lot of part numbers! (IMG:style_emoticons/default/laugh.gif)
For the bulkhead mount, you can probably go through Rich Johnson directly. Might save you a $100. Look in the parts and resources forum for his 914-6 stuff. Other than that, PP has pretty decent prices. I think GPR would be better on them though. (IMG:style_emoticons/default/wink.gif) |
jdogg |
Nov 29 2004, 01:30 PM
Member Group: Members Posts: 431 Joined: 28-January 03 From: Youngsville, NC Member No.: 204 |
Paragon is my favorite. Good prices, prompt shipping, and Jason is very helpful and knowledgable about our little cars.
http://www.paragon-products.com/ |
Lo-Fi Version | Time is now: 4th May 2024 - 10:47 PM |
