fuel system question |
last337 |
Jun 7 2013, 06:38 PM
Member Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None |
I have been having a lot of problems with my fuel system. I can't tellif it is the fuel pump or just something in the gas tank. I pulled the outlet hose of the fuel pump to try to pump the remaining gas out of the gas tank.however when I did the fuel pump barely put out a trickle of gas. I disconnected the inlet side of the fuel filter in front of the fuel pump and no remaining guess came out from the fuel tank side. I know there was still some gas in the tank but I was assuming that the pressure had locked it up to where no more gas would come out.what I am wondering now is if its the fuel pump is bad or if its something clogging the outlet of the fuel tank. I did put my finger over the end of the fuel pump outlet and only felt a small amount of pressure it was not pushing my finger off by any means. Is it possible that there is a clog on the outlet side of the tank? WhenI start up the engine it runs for a couple minutes and then when it comes under load it dies. If I let it sit for a few minutes the fuel filter then fills back up with gas and then it will run again for another few minutes. Does anybody have any suggestions of where I should go next.
Cap'n Krusty |
Jun 7 2013, 07:07 PM
Remove the vapor recovery tank on the top of the fuel tank, remove the filler neck, and look in there with a bright flashlight. You'll pretty much know for sure whether or not the tank outlet is plugged or otherwise compromised. The return, too, for that matter. The outlet is the one with the screen over it.
The Cap'n |
last337 |
Jun 7 2013, 08:26 PM
I have never been inside the fuel tank. Is it easy to change the filter on outlet of tank? How much gas should I remove ? Can I do it with 1/4 tank?
--axel-- |
Jun 7 2013, 08:30 PM
Newbie Group: Members Posts: 39 Joined: 12-April 04 From: Lenexa, KS Member No.: 1,920 Region Association: None |
I have never been inside the fuel tank. Is it easy to change the filter on outlet of tank? How much gas should I remove ? Can I do it with 1/4 tank? The filter sock is accessed from the bottom of the tank. It is attached to a washer that is locked in place by the nut under the tank at the outlet tube. |
Mblizzard |
Jun 7 2013, 08:32 PM
Search for a thread called fuel sock. I don't think it can be done with fuel in the tank. There is also a thread that shows you how to do it without removing the tank.
--axel-- |
Jun 7 2013, 08:33 PM
I have never been inside the fuel tank. Is it easy to change the filter on outlet of tank? How much gas should I remove ? Can I do it with 1/4 tank? The filter sock is accessed from the bottom of the tank. It is attached to a washer that is locked in place by the nut under the tank at the outlet tube. My bet would be that there is a crimp in the line between the tank and the filter. Have you done anything that would have crimped or kinked the line (i.e. moved the tank or replaced the fuel filter)? |
last337 |
Jun 8 2013, 07:20 AM
How do I go about unclogging the tank without removing it?
rhodyguy |
Jun 8 2013, 07:59 AM
where is the pump installed? the strainer/sock will be clogged because of all the crap that is prob in the bottom of the tank. once you manage to get the tank empty, there's always a bit left behind, have a catch basin handy. taking the tank out is pretty simple. you'll HAVE to clean the tank! period. there was a recent thread showing how much loose rust there was in a fellow members tank. amazing.
k |
rick 918-S |
Jun 8 2013, 08:14 AM
Hey nice rack! -Celette Group: Members Posts: 20,457 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
How do I go about unclogging the tank without removing it? First do what the cap'n said and us a flashlight to look inside the tank. If it's rusty or there is anything that looks like sediment in the bottom just pull the tank. Siphon out what ever gas you can if you can't get it out of the lines. Jack the car up in the front or all around and place it securely on jack stands. Remove the inspection belly pan under the rack. (four bolts) Find the fuel lines up in there you'll see them. Disconnect the rubber lines. What ever gas is left should start to leak out and run down your arms into your arm pits. If you shave your pits it will burn like hell! I had a gurl tell me that once. Go back up top. You already have the vapor tank removed from your inspection. Remove the center strap that is across the top of the tank. After the strap is clear you can wiggle the tank out of the car. There are two rubber blocks, one on each side of the tank and a couple of felt pads that support the tank and keep it from rubbing on the body. Make note of their location. You will need to put these back as you re-install the tank. Once the tank is out flip it over and remove the nuts that secure the lines to the tank. Order a new fuel sock, clean out both lines. I have seen these clogged to almost no flow. If the tank is rusted you can use a battery charger to de-rust it. Check you tube. There is lots of info on how-to do it. I did it and it works nice. Here's a couple photos of my tank. Oh, and don't reinstall the tank until you replace the plastic lines in the tunnel. We have lost too many 914's to fire from these old brittle plastic lines. Check the member vendor section for a source for stainless line kits. |
rhodyguy |
Jun 8 2013, 09:00 AM
rick, what's in the tank when you electrify it? that's an AMAZING picture! wow.
last337 |
Jun 8 2013, 05:53 PM
Well after pulling the tank I realized it was a huge mess inside. The sock looked horrible and there was a whole layer of water separated from gas. So after a pressure washer, a gallon of muriatic acid, lots more water , baking soda, denatured alcohol, and a few hours it books like this. I wonder how it even ran before but at least I found the source of all my fuel system issues. I bet I can finally get my carbs balanced right now (IMG:style_emoticons/default/wink.gif)
turk22 |
Jun 8 2013, 09:39 PM
Treetop Flyer Group: Members Posts: 735 Joined: 27-July 12 From: Cincinnati OH Member No.: 14,725 Region Association: Upper MidWest |
last337 |
Jun 9 2013, 07:44 PM
I can't seem to locate a replacement sock filter for my tank. Does anyone know where to get one?
jbachert |
Jun 9 2013, 07:52 PM
Newbie Group: Members Posts: 40 Joined: 2-January 13 From: Allentown, PA Member No.: 15,329 Region Association: North East States |
I can't seem to locate a replacement sock filter for my tank. Does anyone know where to get one? http://www.tangerineracing.com/stainlessfuellines.htm The screens are all the way at the bottom on the right. Chris is a member of the forums and very helpful with any products which are fuel line related. (He sells other stuff, too.) |
last337 |
Jun 10 2013, 07:55 AM
Thanks! I found the screen on the Tangerine site. I am wondering how hard it is really to replace those tunnel lines. I really want to do it but it just looks like such a pain. Mine are not that brittle and still can bend a bit where they exit the tunnel but still Id like that piece of mind.
The walkthru I did find was pretty extensive then I saw a video on youtube and it looked fairly easy and he didnt remove anything. I will most likely just replace tunnel line since everything past that is new anyways. Does anyone have any feedback on this? |
--axel-- |
Jun 10 2013, 08:28 AM
Thanks! I found the screen on the Tangerine site. I am wondering how hard it is really to replace those tunnel lines. I really want to do it but it just looks like such a pain. Mine are not that brittle and still can bend a bit where they exit the tunnel but still Id like that piece of mind. The walkthru I did find was pretty extensive then I saw a video on youtube and it looked fairly easy and he didnt remove anything. I will most likely just replace tunnel line since everything past that is new anyways. Does anyone have any feedback on this? I just did it by myself. Took about an hour to pull the shifter/console/carpet out, and another hour to run the new line. Add in the time to pull the fuel tank, and you are looking at less than 3 hours. Would have taken less time if I had a helper to help guide the new lines through the front wall. |
--axel-- |
Jun 10 2013, 08:30 AM
Thanks! I found the screen on the Tangerine site. I am wondering how hard it is really to replace those tunnel lines. I really want to do it but it just looks like such a pain. Mine are not that brittle and still can bend a bit where they exit the tunnel but still Id like that piece of mind. The walkthru I did find was pretty extensive then I saw a video on youtube and it looked fairly easy and he didnt remove anything. I will most likely just replace tunnel line since everything past that is new anyways. Does anyone have any feedback on this? I just did it by myself. Took about an hour to pull the shifter/console/carpet out, and another hour to run the new line. Add in the time to pull the fuel tank, and you are looking at less than 3 hours. Would have taken less time if I had a helper to help guide the new lines through the front wall. Also, I did it with the engine still in the car. I did have to remove the right rear wheel to make it easier to feed the line. If you have a lift, this won't be an issue. |
rhodyguy |
Jun 10 2013, 08:31 AM
not that difficult a task to switch the tunnel lines out. imho, with carbs you don't need to bother with the return line if you don't want to. there's a recent thread re capping the return line at the tank. as your tank was crappy i'd invest in 10 feet of new fuel line and shouldered clamps to plumb the carbs. of course, toss the old filter. flush your pump (you bought a rotary iirc. if not now is the time). start new and clean, front to back. i think your carb woes were a direct result of the fouled tank and screen/sock.
last337 |
Jun 10 2013, 08:32 AM
Which pieces did you replace? I am a bit confused about what to order.
--axel-- |
Jun 10 2013, 08:37 AM
Lo-Fi Version | Time is now: 15th May 2024 - 02:48 PM |
