Fiberglass rocker cover question |
r_towle |
Jun 7 2013, 06:50 PM
Custom Member Group: Members Posts: 24,576 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I got the rocker covers with my flares.
They have a 1/8 inch indentation where the jack point cover would go, with the idea that you cut that out when you install them. I have removed my jack point due to rust and I don't want to put them back to just start the process all over again. So, how can I make this indentation smooth with the outside face and eliminate the risk of it popping out or cracking? |
Mike Bellis |
Jun 7 2013, 07:08 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
The can says "Kitty Hair" around here. FLAPS or any plastic shop will have some. Maybe even Walmart. I would scuff the gel coat off the rocker first. I would also add some fiberglass gel to the kitty hair mix. It helps it flow better and fill voids. Then just sand smooth and finish with spot putty. |
rick 918-S |
Jun 7 2013, 07:23 PM
Hey nice rack! -Celette Group: Members Posts: 20,462 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Here's what I would do. Grind the jell coat, either use a fibreglas reinforced filler or mix up some glas resin and mat it in. Grind it, fill it and sand it like anything else.
Lo-Fi Version | Time is now: 20th May 2024 - 03:54 AM |
