How to install the glovebox, I understand is a pain in the ass |
partwerks |
Oct 5 2014, 07:14 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
What if you want to remove the lock? How's that come out?
tumamilhem |
Oct 5 2014, 07:41 PM
LUFTBRIGADE Group: Members Posts: 1,228 Joined: 29-October 12 From: Jacksonville, FL Member No.: 15,092 Region Association: South East States |
Where are the "Money Shots"? The ones showing the springs being attached. (IMG:style_emoticons/default/happy11.gif) I tried for weeks last year. Again this year. I can't get the damn springs in to save my life. I prefer them in because I like how the door closes with them. But I can't do it. Lord knows I've tried. Over... And over... And over... (IMG:style_emoticons/default/headbang.gif) |
EdwardBlume |
Oct 6 2014, 12:21 AM
Pull the radio get in there. If you need extra space take the side bolt off. You can do it!
mzapisek |
Oct 6 2014, 09:07 AM
Member Group: Members Posts: 91 Joined: 10-June 04 From: Syracuse, NY Member No.: 2,188 Region Association: North East States |
Just did this yesterday. The springs are a real pain. Left side is much easier to get at through the radio opening. If you loosen the lower dash and let it hang down you can then remove the vent box and get better access to the spring on the outside.
I had a hard time getting the 8mm nut started as it was sitting too far down in my socket. I took some two sided foam tape and suck it to the end of my socket extension to get is started. Once threaded on just pull the tape off and finish tightening with socket. Not fun but not hard. |
Chris Pincetich |
Oct 6 2014, 10:03 AM
I NEED TO DO THIS. I actually damaged one side of the box trying to pry it out. Can't decide if I need to replace it first before re-install.....
THANKS for all the pics and tips (IMG:style_emoticons/default/beerchug.gif) |
clapeza |
Oct 6 2014, 10:11 AM
Member Group: Members Posts: 229 Joined: 7-February 11 From: South GA Member No.: 12,677 Region Association: South East States |
Has someone ever made a replacement fiberglass or plastic glovebox? Seems like a perfect project for 914Rubber or 914ap...
Chester |
Drums66 |
Oct 6 2014, 10:27 AM
.....Fun!!.....in the sun (IMG:style_emoticons/default/happy11.gif)
(IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
EdwardBlume |
Oct 8 2014, 05:21 PM
I NEED TO DO THIS. I actually damaged one side of the box trying to pry it out. Can't decide if I need to replace it first before re-install..... THANKS for all the pics and tips (IMG:style_emoticons/default/beerchug.gif) duct tape should work. (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 3rd June 2024 - 02:53 AM |
