New Pistons & Cylinders, Should I use heavier oil? |
porschefile2010 |
Jun 9 2013, 03:43 AM
Member Group: Members Posts: 228 Joined: 26-May 11 From: Whangaparaoa, New Zealand Member No.: 13,118 Region Association: Australia and New Zealand |
We have just put new PC's in my 2.0 and I have been using valvoline VR1 but a guy told me yesterday that when they run in rally car engines they use a thicker oil. Does that ring any bells with you guys?
I know Penn or my VR1 is ok normally but is it better to run new pots in with heavier oil for a while? |
Jun 9 2013, 06:45 AM
Use break in oil to seat the rings.
Use 20w 50 when running normally. Vr1 or penn have the correct zinc content for the lifters. Penn break in oil also has the correct zinc content. Rich |
dfelz |
Jun 9 2013, 02:16 PM
beach bum Group: Members Posts: 419 Joined: 7-June 12 From: San Diego Member No.: 14,538 Region Association: Southern California |
0396 |
Jun 9 2013, 03:41 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
What's the difference between " break in " vs regular?
monkeyboy |
Jun 11 2013, 03:52 PM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
Use break in oil to seat the rings. Use 20w 50 when running normally. Vr1 or penn have the correct zinc content for the lifters. Penn break in oil also has the correct zinc content. Rich Any other good break in oils besides Penn?? Lucas has a high zinc break in oil, and so does Joe Gibbs. If you want to run the Lucas, text me, and I will let you know where you can get it local. |
porschefile2010 |
Jun 11 2013, 06:17 PM
Thanks for that. I have done a 250 mile oil change to a HPR 30 , 20/60 mineral oil from Penrite so it should be ok
McMark |
Jun 11 2013, 08:50 PM
DBCooper |
Jun 12 2013, 06:35 AM
Irony is they used to sell non-detergent oil. Buy it anywhere oil was sold, it was budget, cheaper than "detergent" oil because they didn't have to add those expensive detergent additives. Now they call that break-in oil, it's hard to find and more expensive.
Jun 12 2013, 09:41 AM
Amsoil might be another option
Lo-Fi Version | Time is now: 8th May 2024 - 12:17 AM |
