Distributor Shaft Wobble, How much is too much? |
warrenoliver |
Jun 9 2013, 10:04 AM
Member Group: Members Posts: 363 Joined: 11-November 06 From: McFarland, Wisconsin Member No.: 7,199 Region Association: Upper MidWest |
I have been trying to chase down a hesitation at about 3000-3200 only when cruising. It accelerates smoothly and runs strong. I have one of Dave's new TPS boards but have not yet put it in. The hesitation is there if the TPS is plugged in or unplugged.
I have noticed the dwell changes and I wonder if I have a bad distributor. When I wiggle the distributor shaft, there is some slop. How much is too much? Should the distributor shaft wiggle at all? |
Bob L. |
Jun 9 2013, 10:20 AM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
The shaft should spin freely and NOT wobble. Wobble is bad. If the dwell is dancing around, no good.
Sounds like you need a new/good one. "914itis" on this board has one available. P.M. him about it. I have a similar hesitation but at lower RPM's and coming off idle. Let us know if/how you get it fixed. Good luck, Bob |
Lo-Fi Version | Time is now: 20th May 2024 - 03:54 AM |
