> Recomendations for the cleaning of electrical connections
Harpo
post Jun 9 2013, 12:36 PM
For the record I did use the search option and was unsuccessful searching
What can I use to clean up my terminals for the electrical connections in my 914? Somewhere I had read something about dielectric grease but I'm thinking I need to clean the terminals first.
Thanks for your help
David
Cap'n Krusty
post Jun 9 2013, 12:59 PM
Cap'n Krusty
Google "electronic contact enhancer" I use Stabilant 22 ($$$$!, available at GM dealers), but there are a lot of good ones out there.
The Cap'n
pcar916
post Jun 9 2013, 01:15 PM
Is that a Lola?
I've used these for 40 years.
http://www.stanleysupplyservices.com/jonar...rnishers/g/8172
Still have the original one. Mine has diamond strips with different grits and came with ~10 strips in the handle.. Once you've cleaned chemically, then with bronze and SS brushes, then start polishing with this. Polish is a way to reduce surface area (against oxygen) and is a corrosion fighting system as well.
Not the harsh file-oriented cleanup but this is where you build in further problems, assuming you're not pushing too much current through the connector.
Good luck
DBCooper
post Jun 9 2013, 04:16 PM
14's in the 13's with ATTITUDE
Like the Cap'n says, that or "electrical contact cleaner", which used to be (maybe still are) carbon tetra-chloride. I've used different brands, they all seem to work, in a small can-high price.
stugray
post Jun 9 2013, 06:28 PM
This works good and you can get it at HD:
http://www.homedepot.com/p/CRC-2-26-5-oz-M...er#.UbUdExXnaP8 cleaned
I recently cleaned my ground points on the car (scrub them down until you see the shiny brass under all that crap.
Then I sprayed all of the parts with the contact cleaner and put it back together.
Stu
- Lo-Fi Version Time is now: 15th March 2026 - 11:37 AM
