fender flaring?, off road tech. applied to a 914? |
Aaron Cox |
May 20 2003, 09:05 PM
hi guys...
my neighbor has a ford ranger and he wants to be able to stick some "meat" under the rear fender. he has fg flares up front, so he needed to flare his rears. so what he did was take a scissor jack or two and put it between the frame and the fender and slowly opened it. he made a smooth form out of wood and used it to make the flare smooth. could this be applied to a 914? very subtle flares that could enable some serious "meat" ? or is this essentialy the "baseball bat trick"? |
Aaron Cox |
May 20 2003, 09:10 PM
this is what i mean.....lodge the jak between inside of fender well and inside of fender with a formed shape,
Aaron Cox |
May 20 2003, 09:12 PM
lines on the bottom of the screen are "shaped pieces/ form" and you push that in the outward direction slowly....could this be done? (IMG:style_emoticons/default/mellow.gif)
Aaron Cox |
May 20 2003, 09:16 PM
could gain an inch or three....
(blue indicates new "shape" of fender) Attached image(s) |
Andyrew |
May 20 2003, 11:21 PM
It sounds alot like the baseball bat trick, although this one sounds like it 'could' work with better success. I really dont know, Im just bumping this cus I wana know..
driver66 |
May 21 2003, 04:45 AM
Member Group: Members Posts: 71 Joined: 11-May 03 From: sullivan,illinois Member No.: 678 |
A buddy of mine seen your post {a body man for 14 yrs} and he believes it will work . but suggest doing it to a junk car first. he also says your paint will suffer bad cracks,take it out real slow and it should work. and watch how far you go ,it could pull welds loose beings you wont be able to feel the added tension of the welds.
Curvie Roadlover |
May 21 2003, 04:50 AM
Two trunks are better than one! Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 |
I'd be worried it would stretch the gaps between the fenders and the doors.
ChrisFoley |
May 21 2003, 05:39 AM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
You will be able to change the shape, but not stretch the metal with this technique. The loads are spread out too much. While this will give a smooth shape it won't move far before other places start to give. My guess is you won't get more than an inch. Also, the inner fender will be deformed unless there is a way to spread the loads at the inner end of the jack as well.
rhaas |
May 21 2003, 06:30 AM
Member Group: Members Posts: 63 Joined: 16-January 03 From: Bay Saint Louis, MS Member No.: 155 |
I did this on my Nissan truck to gain a little room, it changes the door gaps if you want to get any real clearance in the fender. I got about an inch of flare, but my door gap at the bottom is now about 3/8". I wouldn't try it on a nice car.
John Kelly |
May 21 2003, 07:51 AM
Senior Member Group: Members Posts: 692 Joined: 1-May 03 From: Moclips WA. Member No.: 640 |
The only way that would be much better than the bat method would be if the rest of the perimeter of the fender were restrained so that you would actually be stretch forming. This would require an extensive heavy duty frame system to hold the fender in place, and would be hard to control.
John www.ghiaspecialties.com |
anthony |
May 21 2003, 08:29 AM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
There's a guy that showed up to the Roadglue drive on September 14th who had done this to his fenders so he could fit 7" wide Fuchs on the rear.
Actually he explained that the body shop had done it prior to painting. I'd guess that it stretched about 1/2 inch. They also rolled the fender lip. He said they left the jacks in place for like two days so the fenders would take the stretch permanantly. |
airsix |
May 21 2003, 10:43 AM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
There is a gent in the Seattle/Olympia area with a nice silver car shod with 8" fuchs and 245's. He used the fender-pushing method with some wooden forms and a porta-power. The only noticeable downside is it DID stretch the door gap some (he had to point it out to me). It still looks great though. A few years ago at a gathering in Rennton I was looking at it. I was soaking in the great paintjob and had been looking the car over for several minutes before I figured out what I was seeing. Very well done. (He did say the body shop had to clean it up a little when it was in for the paintjob).
-Ben M. |
URY914 |
May 21 2003, 12:58 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,708 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I used a jack in the same way you're talking about on my rear fenders. I had to use two jacks at once and some pieces of plywood to spread the load out-using one jack just puts a dent in the fender. It will work but the metal will stretch when jacked out and than it will return to nearly where it was when you started. So you have to really be careful and jack it out, than block it, than re-jack it out.
Paul |
Dman |
May 21 2003, 04:43 PM
Member Group: Members Posts: 163 Joined: 18-February 03 From: Sacramento CA Member No.: 311 |
I started doing this on my car with a small hydraulic jack, wood blocks and some foam.
I don’t think the block was long enough because I ended up getting a vertical crease in the top of my fender so I stopped. I will probably do it some more when I get a better idea how far I need to go. The crease went in and is totally fixable. I would be careful and go slow, push on a large area. (IMG:style_emoticons/default/smash.gif) |
Mueller |
May 21 2003, 04:57 PM
I did something similar, but I had to cut the fender to make it look correct...I welded in new metal...once done, the average person would think the fenders had not been modified
Fender Mods The picture is after I did the body work.....16x8 with 225's under "stock" fenders (IMG:http://members.rennlist.com/mueller/RearPrimerView.jpg) |
Bleyseng |
May 21 2003, 05:37 PM
I rolled my fenders so the 205x50 Kuhmo's on 7x15 cookies would fit. Started with a 1 1/2" pipe and that wasnt enough. Used a 2 1/2" piece then went to a 4x4 piece of wood. I still need to do some body work to make them look alright but for AX who cares.
Geoff Attached image(s) |
seanery |
May 21 2003, 05:55 PM
Geoff,
What's up with the gray and black lines? leftover pinstripes? |
Aaron Cox |
May 21 2003, 06:17 PM
QUOTE(John Kelly @ May 21 2003, 05:51 AM) The only way that would be much better than the bat method would be if the rest of the perimeter of the fender were restrained so that you would actually be stretch forming. This would require an extensive heavy duty frame system to hold the fender in place, and would be hard to control. John www.ghiaspecialties.com sorry for the lame photshop editing....but is this what you mean? green is the "restraining frame" ...something that spread out the load on the inner fenderwell and went up along side of car to prevent over stretching of perimeter? Attached image(s) |
Bleyseng |
May 21 2003, 06:36 PM
At one time it had a fancy gold and black pinstripe motif. The hood was pretty cool too.
I saw them in 76 with this on them at the dealer, pinstripes were really big then. Atleast this car didn't get the godawful bodyside molding that every dealer put on. Geoff |
Bleyseng |
May 21 2003, 06:41 PM
Here is a pic of Eric Frys car running 225 Hoosiers. He used a porta pull to stretch the fenders to make them fit. Note the bottom of the door gap!
Lo-Fi Version | Time is now: 19th May 2024 - 11:32 PM |
