Seal or no seal? |
Seal or no seal? |
last337 |
Jun 11 2013, 07:32 AM
Member Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None |
So I have been reading about all the seal system kits etc for fuel tanks and after cleaning all the gunk out of mine I wonder if sealing it is really necessary. I looked at POR-15's website and they say if the tank doesnt have any pin-holes or leaks it doesnt need to be sealed at all. However, my thinking is that if I have it all apart anyways whats the harm in sealing it now? Any opinions on this?
nathansnathan |
Jun 11 2013, 08:13 AM
Senior Member Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
I would not seal it. You can introduce problems of the sealer cracking around the outlet/at the edge of any opening, flaking off and clogging the outlet. A good unsealed tank is better than a sealed one. A sealed good one is only as good as a sealed one that had been filled with rust, so keep what you have, the best option available, until you need to do otherwise.
rhodyguy |
Jun 11 2013, 08:39 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
no telling how long, if ever, its been since the tank has been serviced. don't fix what aint' broke. i've never por-15ed a tank. some have success and others haven't. i believe proper prep is crucial for adhesion. did the shop test it for any leaks?
k |
worn |
Jun 11 2013, 09:43 AM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
So I have been reading about all the seal system kits etc for fuel tanks and after cleaning all the gunk out of mine I wonder if sealing it is really necessary. I looked at POR-15's website and they say if the tank doesnt have any pin-holes or leaks it doesnt need to be sealed at all. However, my thinking is that if I have it all apart anyways whats the harm in sealing it now? Any opinions on this? I think the jury won't be in about sealing till a lot of sealed tanks remain problem free at say 20-30 years. You can get them back to clean metal as they were when installed as long as the rust hasn't gone too far. Maybe the sealer will fill pits, but for how long? |
rhodyguy |
Jun 11 2013, 09:53 AM
if the sealant fails you'll wind up further back than go. further back than 'on your mark'
last337 |
Jun 11 2013, 11:44 AM
Yes I was kinda thinking same thing. I had no leaks before muriatic acid treatment so why would that create leaks unless it broke loose some stuff that was keeping it tight. I guess we shall see if I get leaks after putting it back together but as far as seams go it looks good along all of them. I almost bought por15 stuff but friend talked me into muriatic acid route and it worked great!
matt5596 |
Jun 11 2013, 02:57 PM
Member Group: Members Posts: 102 Joined: 28-September 11 From: Norris, TN Member No.: 13,619 Region Association: South East States |
I went in circles on this with the guy that cleaned my tank. He swears by "his" technique. I decided against it - figured as long as I keep it full of alcohol-free gas it will last another 42 year.
Lo-Fi Version | Time is now: 20th May 2024 - 10:27 AM |
