Heater Blower, question about install |
lsintampa |
Jun 12 2013, 01:37 PM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
(IMG:style_emoticons/default/WTF.gif)
Here I go again... 75 914/4 2.0 My heater blower motor (that mounts in the rear engine area next to the relay board) only has ONE output opening for a hose. I don't see in any of the PET or online places that such a motor even exists. All the ones I see have two ports for hose connections. So, am I missing parts or is this another oddity? BTW - I'm 90% certain I have a CA car. Thanks, Confused in Tampa, Len |
reharvey |
Jun 12 2013, 01:55 PM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
Yours is the correct one for a 75. Only one outlet.
SirAndy |
Jun 12 2013, 02:04 PM
Resident German Group: Admin Posts: 41,649 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Only one outlet. (IMG:style_emoticons/default/agree.gif) They switched to a one outlet blower in later years and blocked off the passenger side air inlet. The earlier style two outlet blower mounts directly to the engine (with a bracket). (IMG:style_emoticons/default/popcorn[1].gif) |
TheCabinetmaker |
Jun 12 2013, 02:11 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I'm doing this from memory. Someone please correct me if I'm wrong.
The very early models had two outlets on the fan 180 degrees from each other. 72 or 73 and later had one outlet. The hose ran to the drivers j tube, and the passengers was blocked off. In 75/76 there was a two way splitter that fit on the single outlet and supplied a hose to both sides. I'm not sure if all late cars came with the splitter or not. |
steuspeed |
Jun 12 2013, 02:46 PM
Senior Member Group: Members Posts: 1,006 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Auto Atlanta sells a heater blower kit with Y adapter for the single outlet fan.
http://www.autoatlanta.com/Porsche-Heater-...PN-BMIS400.html If you don't care about heat or defrost then leave it alone. I installed this in my car and it does help with defrost and warming my passengers toes. |
Dave_Darling |
Jun 12 2013, 11:19 PM
The 70-72 fans had two outlets, 180-degrees from each other.
The 73-74 cars had fans with a single outlet, hooked only to the driver's side J-tube. The passenger's side one was capped with a plastic cap that had the VW logo and a part number on it. The 75-76 cars had the single-outlet fans, but there was a splitter attached to that single outlet so hoses could run to the J-tubes on both sides. The OP's car could be an early-75 that was using the 74-style parts because they were on hand. There are a number of other instances of similar things happening around model-year transitions. --DD |
lsintampa |
Jun 13 2013, 10:39 AM
So cars with the single blower motor outlet driver was nice and toasty and the passenger had a blanket..
Ok that makes sense - keep the passenger awake, put the driver to sleep. (IMG:style_emoticons/default/confused24.gif) |
wrightee |
Jun 13 2013, 04:42 PM
Member Group: Members Posts: 83 Joined: 18-November 09 From: Montclair, VA Member No.: 11,053 Region Association: MidAtlantic Region |
The 70-72 fans had two outlets, 180-degrees from each other. The 73-74 cars had fans with a single outlet, hooked only to the driver's side J-tube. The passenger's side one was capped with a plastic cap that had the VW logo and a part number on it. The 75-76 cars had the single-outlet fans, but there was a splitter attached to that single outlet so hoses could run to the J-tubes on both sides. The OP's car could be an early-75 that was using the 74-style parts because they were on hand. There are a number of other instances of similar things happening around model-year transitions. --DD My '75 1.8L has the single hose with the passenger side capped...but I've also noted that my vacuum hoses match up with the diagram for the 74 more so than the diagram for the 75 (only a single vacuum line on the air plenum)...so maybe I've got one of those tweener year teeners. |
Drums66 |
Jun 13 2013, 05:05 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
I'm doing this from memory. Someone please correct me if I'm wrong. The very early models had two outlets on the fan 180 degrees from each other. 72 or 73 and later had one outlet. The hose ran to the drivers j tube, and the passengers was blocked off. In 75/76 there was a two way splitter that fit on the single outlet and supplied a hose to both sides. I'm not sure if all late cars came with the splitter or not. (IMG:style_emoticons/default/rock_band.gif) (IMG:style_emoticons/default/thumb3d.gif) |
GaroldShaffer |
Jun 13 2013, 05:12 PM
You bought another 914? Group: Benefactors Posts: 7,622 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
So cars with the single blower motor outlet driver was nice and toasty and the passenger had a blanket.. Ok that makes sense - keep the passenger awake, put the driver to sleep. (IMG:style_emoticons/default/confused24.gif) Not really. The heat is still hooked up from the exchanger just no blower to "help" push the warm air along. My 70 doesn't have any blower installed and as long as I'm moving I have plenty of heat. (IMG:style_emoticons/default/biggrin.gif) |
TheCabinetmaker |
Jun 13 2013, 05:25 PM
Yep, the blower is just for when idleing. It's called an auxiliary fan.
Drums66 |
Jun 13 2013, 05:48 PM
So cars with the single blower motor outlet driver was nice and toasty and the passenger had a blanket.. Ok that makes sense - keep the passenger awake, put the driver to sleep. (IMG:style_emoticons/default/confused24.gif) ....With the right lady,the heat is always on!....use the blower sometimes (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/bye1.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 06:07 AM |
