Windshield Washer |
Windshield Washer |
lsintampa |
Jun 13 2013, 02:52 PM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
75 914/4 2.0
I removed the old tubes for the windshield washer system - all of them. Read the tech article about hooking up motor to the system. Seems very straight forward. There was a spare tire line that ran to the washer container. I assume it pressurized the tank so when you wanted to squirt some cleaner on your windshield there was something to push the fluid out. A tube ran out the bottom all the way to the column then went into some turnabout nipple thing and came back out to the nozzles. My question: Is that turn around nipple thing the "release" of pressure that will allow fluid to flow? That means it's mechanical? Or is it? Just curious how it works. I noticed that there also is a switch that makes contact in the steering column when you pull back on the wiper arm. On my car, the black/brown wire up front was just cut off and hanging out. I'm not sure if I have intermittent wipers or not. There's no sign of a relay of any kind on the brace where the wiper motor is. Don't know how to tell, unless all 75's had em. Anyway, I'm hoping that black/brown goes hot when the wiper arm is pulled back, cause that's how I hooking the washer motor up. I'm really starting to enjoy this thing... gets better each day. (IMG:style_emoticons/default/popcorn[1].gif) Len |
914Sixer |
May 30 2017, 03:08 PM
The key to doing the conversion is the switch. Reproduction switches are now available, can't remember the part number off the top of my heard. Want to say it ends with the letter H
kgruen2 |
May 31 2017, 02:10 AM
Member Group: Members Posts: 109 Joined: 22-February 15 From: Prescott, Az. Member No.: 18,459 Region Association: Southwest Region |
The key to doing the conversion is the switch. Reproduction switches are now available, can't remember the part number off the top of my heard. Want to say it ends with the letter H I just had an electric washer pump motor installed in mine. I used a simple "momentary " toggle switch. It is a spring loaded toggle switch which you just push up to spray and release to stop. Works great. You do have to hit the wiper switch separately, though. Up on toggle to spray, hit wiper switch to wipe. |
Olympic 914 |
May 31 2017, 06:40 PM
Group: Members Posts: 1,670 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
The key to doing the conversion is the switch. Reproduction switches are now available, can't remember the part number off the top of my heard. Want to say it ends with the letter H I just had an electric washer pump motor installed in mine. I used a simple "momentary " toggle switch. It is a spring loaded toggle switch which you just push up to spray and release to stop. Works great. You do have to hit the wiper switch separately, though. Up on toggle to spray, hit wiper switch to wipe. I set mine up the same way, with a momentary switch under the dash. Pull it towards you to activate the squirters and hit the lever for the wipers. (IMG:style_emoticons/default/beerchug.gif) |
kgruen2 |
Jun 1 2017, 01:56 AM
The key to doing the conversion is the switch. Reproduction switches are now available, can't remember the part number off the top of my heard. Want to say it ends with the letter H I just had an electric washer pump motor installed in mine. I used a simple "momentary " toggle switch. It is a spring loaded toggle switch which you just push up to spray and release to stop. Works great. You do have to hit the wiper switch separately, though. Up on toggle to spray, hit wiper switch to wipe. I set mine up the same way, with a momentary switch under the dash. Pull it towards you to activate the squirters and hit the lever for the wipers. (IMG:style_emoticons/default/beerchug.gif) All this for a little squirt. Very cool. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 03:42 AM |
