Windshield Washer |
Windshield Washer |
lsintampa |
Jun 13 2013, 02:52 PM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
75 914/4 2.0
I removed the old tubes for the windshield washer system - all of them. Read the tech article about hooking up motor to the system. Seems very straight forward. There was a spare tire line that ran to the washer container. I assume it pressurized the tank so when you wanted to squirt some cleaner on your windshield there was something to push the fluid out. A tube ran out the bottom all the way to the column then went into some turnabout nipple thing and came back out to the nozzles. My question: Is that turn around nipple thing the "release" of pressure that will allow fluid to flow? That means it's mechanical? Or is it? Just curious how it works. I noticed that there also is a switch that makes contact in the steering column when you pull back on the wiper arm. On my car, the black/brown wire up front was just cut off and hanging out. I'm not sure if I have intermittent wipers or not. There's no sign of a relay of any kind on the brace where the wiper motor is. Don't know how to tell, unless all 75's had em. Anyway, I'm hoping that black/brown goes hot when the wiper arm is pulled back, cause that's how I hooking the washer motor up. I'm really starting to enjoy this thing... gets better each day. (IMG:style_emoticons/default/popcorn[1].gif) Len |
Mike Bellis |
Jun 13 2013, 03:16 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
There is a mechanical valve in the turn signal stalk. I'm surprised we don't hear about leaking steering columns more often...
Dave_Darling |
Jun 13 2013, 06:54 PM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
There is a mechanical valve in the turn signal stalk. I'm surprised we don't hear about leaking steering columns more often... I think that's because most people have unhooked the stock system by now, due to wet laps. I am told that you can use a 924 wiper stalk and switch in the 914 column, and it has an electrical switch that closes when you pull back on the stalk so you can run an electric washer pump. --DD |
tomeric914 |
Jun 30 2017, 06:38 PM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
Valy |
Jun 30 2017, 08:23 PM
Senior Member Group: Members Posts: 1,675 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
I am told that you can use a 924 wiper stalk and switch in the 914 column, and it has an electrical switch that closes when you pull back on the stalk so you can run an electric washer pump. That is correct... and someday I will actually hook mine up! This is what you need: http://www2.cip1.com/ProductDetails.asp?Pr...4-111-953-519-G But for whatever reason, many people here will tell you that drilling the dash and installing an ugly momentary switch, that doesn't trigger the wipers at the same time, is the way to go. Do whatever works for you. You can search and find a thread on how to mount the switch and add a smart intermittent relay too. |
Lo-Fi Version | Time is now: 18th May 2024 - 03:41 AM |
