Broken Impeller Blade, Does it matter??? |
d7n7master |
Nov 30 2004, 11:51 AM
Gary# Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 |
Hi All,
While installing the impeller I noticed a missing blade & found two more that are cracked. See pic. The book says it's a "balanced" assy... more like "was"!!! (IMG:style_emoticons/default/sad.gif) What should I do now??? Thanks, Gary Attached image(s) |
Eric_Shea |
Nov 30 2004, 11:58 AM
That's common. People like to stick screwdrivers in there when changing the fan belt or getting the engine to turn for a tune up etc.
Call here and talk to the Cowboy. I'm "guessing" Rich'll have 1 or 2 laying around (IMG:style_emoticons/default/laugh.gif) Oh... and yes, it's best to get a new one and keep the assembly balanced. |
d7n7master |
Nov 30 2004, 12:13 PM
Thanks - Damn!!! (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/chair.gif)
Brett W |
Nov 30 2004, 12:16 PM
You want the cheap way? Go to the exact opposite side of the fan and remove corresponding blades. Very carefully polish the remaining casting flash and run it as is. You should not ever have a problem with it.
d7n7master |
Nov 30 2004, 12:54 PM
Remove the opposite blade, not a bad idea, except that it has two other blades that are cracked as well.
I'm gonna go ahead & replace it now while the engines still out of the car. Thanks, Gary |
skline |
Nov 30 2004, 12:56 PM
Porsche says never run one with more than 3 missing blades. That is all I have to say.
ruddyboys |
Nov 30 2004, 01:14 PM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
I remember seeing a post awhile back about how all but a few blades were removed for better air flow or maybe I had a few too many Buds.
Eric_Shea |
Nov 30 2004, 01:22 PM
Hmmmmm. Let me get this straight: (IMG:style_emoticons/default/idea.gif)
We're looking at an engine that's currently out of the car, has a missing fan blade and has a few more cracked blades. Last I checked, I couldn't sell a spare fan for $10.00 and the consensus is "to remove more blades at this time..." (IMG:style_emoticons/default/smilie_pokal.gif) Sounds good to me. (IMG:style_emoticons/default/laugh.gif) |
d7n7master |
Nov 30 2004, 02:33 PM
I just checked the bird parts website. They have a "new" fan for $271. - & rebuilds are NLA.
I'll call HPH next... Thanks, Gary |
Eric_Shea |
Nov 30 2004, 02:41 PM
I had one FS in the classified here for quite some time. Finally sold it for around $10.00.
914werke |
Nov 30 2004, 02:43 PM
"I got blisters on me fingers" Group: Members Posts: 10,060 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
QUOTE Porsche says never run one with more than 3 missing blades. That is all I have to say. Huh! where does it say that? |
type47 |
Nov 30 2004, 02:45 PM
... the "remove the blades" thread was referring to race track only cars.....
machina |
Nov 30 2004, 03:34 PM
here's mine
they snap off pretty easy with some pliers. Then grind for a while. Attached thumbnail(s) |
Jake Raby |
Nov 30 2004, 03:44 PM
Damn that thing was a bitch for me to balance!!
Curvie Roadlover |
Nov 30 2004, 05:51 PM
Two trunks are better than one! Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 |
QUOTE(d7n7master @ Nov 30 2004, 01:54 PM) Remove the opposite blade, not a bad idea, except that it has two other blades that are cracked as well. Crack the blades exactly opposite of the already cracked ones (IMG:style_emoticons/default/smile.gif) |
redshift |
Nov 30 2004, 05:54 PM
I thought they worked better if you alternate, cutting out groups of four?
This was a big discussion around here once. Added a handful of horsepower. M |
redshift |
Nov 30 2004, 05:56 PM
QUOTE(Eric_Shea @ Nov 30 2004, 03:22 PM) I couldn't sell a spare fan for $10.00 and the consensus is "to remove more blades at this time..." (IMG:style_emoticons/default/smilie_pokal.gif) Sounds good to me. (IMG:style_emoticons/default/laugh.gif) ROFL Eric... it's just too funny. ©M |
tracks914 |
Nov 30 2004, 06:40 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
Go here quick and snap this puppy up.
Fan on Ebay Ask the seller if it has all the blades BEFORE you bid. |
d7n7master |
Nov 30 2004, 06:50 PM
Hi All,
You'se guys crack me up!!! (IMG:style_emoticons/default/boldblue.gif) So much info - thanks soooo much - now I've got "options" (IMG:style_emoticons/default/beerchug.gif) Awesome! I had NO idea that removing blades was even an option. But it did make me think... Many years ago I was a tech/mech for a large aircraft engine accessory manufacturer. One of my many tasks was to overhaul (ACM's) Air Cycle Machines. The overhaul was a piece 'o cake. The dynamic balancing was a stone BITCH!!! (IMG:style_emoticons/default/headbang.gif) But once you learned to balance - your next raise was a sure thing. BTW - Removing blades was NOT an option... (IMG:style_emoticons/default/alfred.gif) (IMG:style_emoticons/default/cool_shades.gif) This is my daily driver (once I surgically remove her from the jack stands). I'm in O.C. Ca. & it gets HOT here. So I'm thinkin' I need ALL of the blades for those times when I'm stuck in traffic on a 90+ day. Am I wrong??? Tell me - I can take it. Thanks again, Gary Soap-Box: (IMG:style_emoticons/default/beer3.gif) This is the type of help I have always appreciated from ALL of you/us teener people. We have fun, take our shots, have a few laughs, and exchange a wealth of info that helps keep/get our amazing 'lil cars running & on the road. and DOOOHHH - we DON'T discuss politics. CAUTION: Do NOT attempt these (noob) questions on the RX-7 board. (IMG:style_emoticons/default/pissoff.gif) |
TheCabinetmaker |
Nov 30 2004, 06:57 PM
QUOTE(d7n7master @ Nov 30 2004, 06:50 PM) CAUTION: Do NOT attempt these (noob) questions on the RX-7 board. :pissoff: Can the Mazda guys answer 914 questions? (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 12:28 PM |
