Looking for Rocker arm bolts |
pcdarks |
Jun 23 2013, 03:52 PM
Member Group: Members Posts: 80 Joined: 22-June 13 Member No.: 16,037 Region Association: None |
I stripped the threads on a rocker arm bolt on a 1.7 engine. It's the bolt that has larger threads going into the head. Any help finding replacements?? Thanks Also I will want new nuts too.
BajaXJ92 |
Jun 23 2013, 04:14 PM
Extended Member Group: Members Posts: 2,146 Joined: 20-April 06 From: Prescott, AZ Member No.: 5,895 Region Association: MidAtlantic Region |
Try the "Want to Buy/For Sale" Section.
How do you strip rocker arm bolts? Do you own a torque wrench? (IMG:style_emoticons/default/confused24.gif) |
pcdarks |
Jun 23 2013, 04:43 PM
Actually I think they were galled when they came off. They were very hard to turn all the way. yes I own a torque wrench but the damage was done by the time they went back on. 1 stud for sure and another I will replace to be safe the other two are fine. Are they the same for VW engines? There is a VW shop in SLC that might have them.
Cap'n Krusty |
Jun 23 2013, 05:17 PM
Ask 'em for "studs", 'cause that's what they're commonly called.
The Cap'n |
pcdarks |
Jun 23 2013, 07:54 PM
What "type" engine is the 1.7? If it is the same as a VW then needing a Porsche part may make it more expensive.
gothspeed |
Jun 23 2013, 09:19 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
european motorworks has upgraded versions for great prices (IMG:style_emoticons/default/smile.gif)
here is the link: http://www.europeanmotorworks.com/pvw/054-...er+Arm+Stud+T-4 |
Jun 24 2013, 08:51 AM
All of the 914-4 engines are "Type IV" motors. So if you're asking for parts at a VW place, ask for those.
--DD |
pcdarks |
Jun 24 2013, 05:21 PM
Success, local shop had two.
Lo-Fi Version | Time is now: 17th May 2024 - 09:32 PM |
