Steve's 73 1.7 Restoration Thread |
Steve_R |
Jun 23 2013, 11:32 PM
Member Group: Members Posts: 68 Joined: 8-August 12 From: San Diego, CA Member No.: 14,777 Region Association: None |
Hi, I would like to introduce myself and share my project. I’m Steve, I live in San Diego and I picked up this 1973 1.7 914 about a year ago. It was in great shape with no rust and had been sitting in a garage for the past 13 years. My plan is to restore it to its original condition. At this point I think the car is about 50% done.
The car had door guards riveted to the sides and I had them welded up. One of the first things I did when I got the car was to build a dolly to be able to work on the suspension and make it easy to move it around the garage. It’s made from 4 X 4s and plywood and it took about 4 hours to build. If you don’t have a wood saw Home Depot will cut the 4 X 4s and plywood to the correct length. There are lag screws on top of the vertical posts that stick up ½” that fit into the 4 jack points cups under the car. This keeps the car from falling off. Also, I removed the engine before I put the car on it. To get it up there I used some cement blocks, 4 jack stands and 2 scissor jacks. Over the past year I’ve learned a lot from reading your posts and now I would like to give back some of the knowledge I’ve learned. Attached image(s) Attached File(s) Dolly.pdf ( 97.5k ) Number of downloads: 277 |
watsonrx13 |
Aug 18 2013, 07:51 AM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Excellent work. Can you show some pics of the paint booth set up?
--- Rob |
Steve_R |
Aug 18 2013, 09:11 AM
Rob,
I didn't use a paint booth. I painted it in the drive way in the morning when there wasn't any wind. Also I hosed down the driveway to keep the dust down. On the whole car I got two small flies in the paint that I was able to pick out with tweezers. I think the two stage base coat/clear coat paint makes it easier to paint without a paint booth. You can easily fix problems (bugs, runs) in the base coat. Since you sand and buff the clear coat, it's easy to fix problems. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:36 AM |
