Steve's 73 1.7 Restoration Thread |
Steve_R |
Jun 23 2013, 11:32 PM
Member Group: Members Posts: 68 Joined: 8-August 12 From: San Diego, CA Member No.: 14,777 Region Association: None |
Hi, I would like to introduce myself and share my project. I’m Steve, I live in San Diego and I picked up this 1973 1.7 914 about a year ago. It was in great shape with no rust and had been sitting in a garage for the past 13 years. My plan is to restore it to its original condition. At this point I think the car is about 50% done.
The car had door guards riveted to the sides and I had them welded up. One of the first things I did when I got the car was to build a dolly to be able to work on the suspension and make it easy to move it around the garage. It’s made from 4 X 4s and plywood and it took about 4 hours to build. If you don’t have a wood saw Home Depot will cut the 4 X 4s and plywood to the correct length. There are lag screws on top of the vertical posts that stick up ½” that fit into the 4 jack points cups under the car. This keeps the car from falling off. Also, I removed the engine before I put the car on it. To get it up there I used some cement blocks, 4 jack stands and 2 scissor jacks. Over the past year I’ve learned a lot from reading your posts and now I would like to give back some of the knowledge I’ve learned. Attached image(s) Attached File(s) Dolly.pdf ( 97.5k ) Number of downloads: 277 |
stevegm |
Oct 14 2014, 09:25 PM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
Wasn't there a picture on 914world of this car (or maybe another car) being rolled onto a car trailer on a wood dolly like Steve used in this thread? I am just wondering if the wood dolly here:
http://www.914world.com/bbs2/index.php?act...t&id=394445 would be strong enough to haul the car, on a car trailer, to the paint shop. What do you think? |
Steve_R |
Oct 14 2014, 10:02 PM
Wasn't there a picture on 914world of this car (or maybe another car) being rolled onto a car trailer on a wood dolly like Steve used in this thread? I am just wondering if the wood dolly here: http://www.914world.com/bbs2/index.php?act...t&id=394445 would be strong enough to haul the car, on a car trailer, to the paint shop. What do you think? Steve, It wasn't this car. I have not put it on a trailer. I think it would work if the engine was out of the car. You could also beef it up a little from these plans. Maybe use 3/4" plywood with 2" deck screws for the gussets. |
stevegm |
Oct 14 2014, 10:11 PM
Wasn't there a picture on 914world of this car (or maybe another car) being rolled onto a car trailer on a wood dolly like Steve used in this thread? I am just wondering if the wood dolly here: http://www.914world.com/bbs2/index.php?act...t&id=394445 would be strong enough to haul the car, on a car trailer, to the paint shop. What do you think? Steve, It wasn't this car. I have not put it on a trailer. I think it would work if the engine was out of the car. You could also beef it up a little from these plans. Maybe use 3/4" plywood with 2" deck screws for the gussets. Thanks. I can also beef it up with a metal strap all the way around. Just curious on your thoughts, since you used the dolly so much. |
Lo-Fi Version | Time is now: 17th May 2024 - 01:37 AM |
