Wire Harness - easy question |
lsintampa |
Jun 28 2013, 02:40 PM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
914/4 75 2.0
Tossing up a softball for you.... Wire harness that starts at the positive battery post - there are a number of positive leads (red wires) that attach to there. Follow the casing down and the very first wire that comes off the casing seems to be a green wire. It is about 10" or so from the start of the harness that hooks to the battery. Where does that green wire attach to? Thanks, Len |
JeffBowlsby |
Jun 28 2013, 02:47 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Its a green/black stripe wire and is the connection to the oil temp sender wire if you have an oil temp gauge in the center console
lsintampa |
Jun 30 2013, 12:50 PM
914itis |
Jun 30 2013, 01:09 PM
Its a green/black stripe wire and is the connection to the oil temp sender wire if you have an oil temp gauge in the center console Is the sender you are speaking about the on under the taco plate? Thanks! Len Yep, it is. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:38 PM |
