2 Pages V < 1 2
> New carbs- one barrel pulling in too much air
McMark
post Jul 2 2013, 12:59 PM
Post #21
914 Freak!
You can't really see if the throttle plates are closing with the carbs on the engine. You need a light on one end and your eyeball on the other.
stugray
post Jul 2 2013, 01:05 PM
Post #22
back off the throttle shaft screws and realign them
you need to be very careful loosening those screws.
They are very hard to get loose (if still factory).
It is too easy to apply too much pressure and bend the shaft.
You can back-up the shaft to keep it from bending but then you need to remove the venturis so you can get a block of wood or something in there.
Stu
rhodyguy
post Jul 3 2013, 08:11 AM
Post #23
for heavens sake. how in the hell, with all 4 by-pass screws closed, do you bring the lowest ones up? backing the screws OUT routes the air flow around, BY-PASSING, the throttle plates and reducing the flow thru the venturi. YOU'VE got it backwards. you back the HIGHEST flowing carb bore(s) screws OUT to match the lowest flowing. again, not to exceed the maximum # of turns recommended. go to far and you lean that cyl(s) out.
McMark
post Jul 3 2013, 11:32 AM
Post #24
914 Freak!
Sorry you're the one that's backwards. All air coming into the engine flows through the ventri, so no matter if the throttle plate is opening, or the air-bypass screw is backing out, that air is flowing through the snail and reading higher.
NOPE! It's does bypass the throttle plate, but it's still flowing through the venturi. Air entering the 'bypass chamber' comes from the main airflow. There isn't a separate air inlet for the bypass. With regards to airflow, backing out the bypass screw is essentially the same as opening the throttle plate.
Jake Raby
post Jul 3 2013, 01:42 PM
Post #25
Engine Surgeon
This was a common issue with the "Genuine" Webers in 2008 when I stopped using them. The throttle shafts were twisted right out of the factory among other issues.
Too many people buy the name expecting them to be the way they always were before. Not the case.
tornik550
post Jul 3 2013, 01:49 PM
Post #26
I found a way to fix my problem. Return the carbs and go back to my old system!!!!
tornik550
post Jul 4 2013, 06:43 PM
Post #27
UPDATE-
The issue appears to be that the throttle shaft on on carb is slightly bent.
Also- I found that the secondary venturi's were installed upside down from the factory!!!! WTF!!! I had just taken them out of the boxes when I noticed that they were opposite to my other weber 44 idf's. I thought that my old ones were messed up. It turns out that the new webers are. How could they make such a stupid mistake.
McMark
post Jul 4 2013, 11:56 PM
Post #28
914 Freak!
They realized that because of their name reputation they can make just as much money without paying attention to little things like 'being correct'.
2 Pages V < 1 2
- Lo-Fi Version Time is now: 31st August 2025 - 07:41 PM
