Custom Gauge lighting, now in color! |
timothy_nd28 |
Jul 2 2013, 04:00 PM
First I would like to thank Kent (76-914) for introducing me to Al's wife Shirlee. She was extremely helpful and sold me all of Al's leftovers. Today, I received a huge box filled with led's, cannibalized gauge housings and a very touching note from Shirlee. I also noticed a dismantled tachometer that Al was working on. I was taken back and felt very sad seeing this tach. You could see all the tedious prep work that Al did, but sadly he wasn't able to complete his masterpiece.
I was determined this afternoon to pick-up where Al had left off, in his honor. This thread is broken up in 3 parts. The first part is intended to show everyone how Al achieved his multicolor gauges. The 2nd part is a "how to" to make your gauges into any color you wish. The last part is another "how to" but taking our gauges to a whole new level. As you will see, my design could have a back light color background in any color that you can think of. My uncle has designed a neat little circuit that works in tandem with the RGB color controller. The circuit senses the tach wire, and changes the color of the back-lighting of all gauges to yellow at a certain rpm, then red at another certain rpm. It is fully customizable as you can set the when yellow comes on, as well as the red. There is another input on this circuit board which turns all the gauges to red when triggered. I thought we could use this special input for the low fuel light, or as a fan belt warning for the 911 types. Perhaps the special input could be hacked into a radar detector, many possibilities. Yellow and redline lights again are fully adjustable via a potentiometers, also this circuit will work for any 4-6-8 cylinder engines. With my last how-to topic, I received many messages from folks that didn't feel comfortable doing this to their own gauges. I have done enough of these in which I feel comfortable. If you're one of these folks, send me a PM and I'll do this conversion for you. For me, it's a 1.5 hour process, but it may take longer for someone that has never done something like this before. I'll try to make this write up detailed as much as possible. |
monkeyboy |
Jul 21 2013, 09:29 AM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
Quick question about the gauge color change. Just to be sure, it only works when the lights are on, right? It's not something that will light up at the shift point when the lights are not on?
I am just trying to be clear on what to expect. I am not looking for a full time shift light myself. |
timothy_nd28 |
Jul 21 2013, 03:28 PM
Quick question about the gauge color change. Just to be sure, it only works when the lights are on, right? It's not something that will light up at the shift point when the lights are not on? I am just trying to be clear on what to expect. I am not looking for a full time shift light myself. I have mine wired so it steals power from one of the original gauge bulbs. So mine only turns on with the headlight switch. You can also wire it to ignition "on" 12v for it to be on all the time. These gauges are bright, but not that bright. The sunlight will most likely overpower these LED's during the daytime. |
Lo-Fi Version | Time is now: 4th May 2024 - 01:57 AM |
