| timothy_nd28 |
Jul 2 2013, 09:17 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest
Here's what inspired my thinking.
https://www.youtube.com/watch?v=k2K2c3QQgSA Pretty close to my design, minus the music. However my design first changes to yellow then to red. Also my design changes the color of all the gauges instead the videos one gauge It should be noted that the yellow light before redline is optional. It can be adjusted so that you can just have red at the redline rpms. We tried to design this circuit board to pacify anyone. |
| StratPlayer |
Jul 2 2013, 09:19 PM
StratPlayer ![]() ![]() ![]() ![]() Group: Members Posts: 3,384 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains
I'm interested....
| monkeyboy |
Jul 2 2013, 11:57 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
I'd be in for a set.
| timothy_nd28 |
Jul 3 2013, 12:11 AM
SirAndy, you do so much for this site. I would be happy to donate one to you for free
| mepstein |
Jul 3 2013, 07:10 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,959 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Tim, this is cool as Fuchs man. Al would be proud and I think you've got a great thing going. Keep up the great work dude. Thanks man, how many can I put you down for? I'm in for one. thanks, mark BTW, this is really awesome. |
| 76-914 |
Jul 3 2013, 08:21 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,988 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Thx Buddy, Al has got to be smiling. He loved doing this and now you have improved upon a valuable service to our community. Very nice work. (IMG:style_emoticons/default/first.gif)
| timothy_nd28 |
Jul 3 2013, 04:06 PM
That or he's gonna come haunt me for giving up all of his trade secrets! (IMG:style_emoticons/default/unsure.gif)
| boogie_man |
Jul 3 2013, 04:59 PM
Member ![]() ![]() Group: Members Posts: 308 Joined: 22-April 11 From: So Cal Member No.: 12,969 Region Association: Southern California |
Those look very, very good. Great workmanship (IMG:style_emoticons/default/piratenanner.gif)
| timothy_nd28 |
Jul 3 2013, 11:05 PM
Ok, I have been going over prices for this. As of right now, I can put a kit together for 95 dollars (all 3 gauges). If you want me to do the labor part, I will charge 100 dollars to install. I will honor this price for the first 10 customers, just to protect me from losing my ass if it goes that way! (IMG:style_emoticons/default/biggrin.gif) Again, it's somewhat hard to pinpoint a final cost due to cost of components and assembly. Most everything on the circuit board are SMT (surface mount) components, which is a PITA to solder by hand. So I will need to invest in a infrared reflow oven to help streamline assembly or outsource to a company that does this.
I believe in this as it has a cool factor to it. It also solves the original problem of our gauges being too dim. Kinda a win-win, and cheap (for the first 10 customers)! |
| mrholland2 |
Jul 3 2013, 11:49 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 761 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
I'm in for this!!!!!!!!!!! (you doing the install)
Sean Ok, I have been going over prices for this. As of right now, I can put a kit together for 95 dollars (all 3 gauges). If you want me to do the labor part, I will charge 100 dollars to install. I will honor this price for the first 10 customers, just to protect me from losing my ass if it goes that way! (IMG:style_emoticons/default/biggrin.gif) Again, it's somewhat hard to pinpoint a final cost due to cost of components and assembly. Most everything on the circuit board are SMT (surface mount) components, which is a PIA to solder by hand. So I will need to invest in a infrared reflow oven to help streamline assembly or outsource to a company that does this. I believe in this as it has a cool factor to it. It also solves the original problem of our gauges being too dim. Kinda a win-win, and cheap (for the first 10 customers)! |
| 914socal |
Jul 4 2013, 12:10 AM
Newbie ![]() Group: Members Posts: 38 Joined: 18-October 12 From: Santa clarita Member No.: 15,059 Region Association: None |
I'm in for a kit and your labor service!
| monkeyboy |
Jul 4 2013, 02:30 PM
I'm in for an installed kit.
| Harpo |
Jul 4 2013, 05:15 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I'm in for the kit & your install services
Thanks David |
| Madswede |
Jul 5 2013, 11:21 AM
Flat Out Driver ![]() ![]() ![]() Group: Members Posts: 853 Joined: 13-September 06 From: Rio Rancho NM Member No.: 6,831 Region Association: Rocky Mountains |
I'm in for a kit! This should work with my gauges I believe, which are standard except the tach is appropriate for a /6.
Tangent: got two oil gauges and volt gauge separated out. They're brighter (well, except oil temp) than the ones on the main dash so they're not too bad, but I'd like to brighten up the oil temp seeing as it's sort of important. Think I might try to salvage lights from the other gauges. |
| timothy_nd28 |
Jul 5 2013, 12:20 PM
Great! This circuit is very diverse as it was designed for our 4 cylinder or 6 or even a 8 cylinder engines. In addition, this will work with the older 200 volt tach signal, 80's style 12 volt tach signal and the the modern 5 volt tach signal. So, I think we have all cars covered with this design.
| Mr.242 |
Jul 6 2013, 11:39 AM
May your glass be smaller so it's always FULL! ![]() ![]() ![]() Group: Members Posts: 1,081 Joined: 10-June 08 From: Seattle Member No.: 9,160 Region Association: Pacific Northwest |
The 'do it yourself' kit....are all the pieces soldered or is that part 'do it yourself' too?
I'd like to do my own gauges, so I'm interested in having just the kit. Love the kit. It would be nice to have the new lights and color option, will seem wrong to put into a SIX, but it's mine and I'll do with it what I want. (IMG:style_emoticons/default/beerchug.gif) I'm debating the changing of the lights to warn of high rpm's just because I wouldn't want to see it change often if I am reving the motor. I'm holding off my decision on that one. The low gas light....would it be able to change then entire color AND light the low light warning? or will the low gas light not operate with this change? |
| timothy_nd28 |
Jul 6 2013, 03:37 PM
It would be mighty cruel of me to give you a board with a bag full of parts. These parts are miniature components that will need to be soldered with great accuracy. It was my intention to assemble the board and sell it as a working controller. You would be responsible for calibrating the circuit, so you'll need a function generator or adjust the pots with the engine running. There is some cool free apps for your phone that may work as a function generator.
For the purist, my mod to the gauges will not require any cutting into the cars wiring harness. This will be a pretty clean install for the most part. We still need to figure out where to mount the controller, but there seems to plenty of room under the dash behind the gauges. |
| timothy_nd28 |
Jul 6 2013, 03:59 PM
I should be clearer. If you want the kit and for me to do the labor, I will do the calibration for you. When this gets rolling, all that I need is your gauges and what RPMs you wish the lights to turn on and off at. When I mail your gauges back to you, all you need to worry about is just reinstalling back into the car.
| poorsche914 |
Jul 6 2013, 06:22 PM
9fourteen ![]() ![]() ![]() ![]() Group: Members Posts: 3,163 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
Count me in for a kit. Does it include the LED strips or do we need to source those elsewhere?
(IMG:style_emoticons/default/driving.gif) |
| timothy_nd28 |
Jul 6 2013, 06:55 PM
Yep, the DIY kit will have enough led strip to do the 3 gauges and the flat ribbon cable needed to solder to the led strips.
Lo-Fi Version | Time is now: 28th October 2026 - 05:33 AM |
