Can I put 2.0L rockers on a 1.8? |
stugray |
Jul 6 2013, 11:30 AM
I assume that they should fit just fine.
Stu |
stugray |
Jul 6 2013, 12:08 PM
I will clarify: I stole the 1.7/1.8 rockers from my running 1.8L to convert a 2.0L to the swivel feet.
Now can I put the 2.0L rockers on the 1.8L that I "raped" for it's rockers. Obviously I need to readjust the valves afterwards... Stu |
Jul 6 2013, 12:44 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Yes, you can. Since I'm a wee bit superstitious, I would consider swapping the rocker shafts and associated bits over as well as the rocker arms. Just in case the parts have "worn in" to each other.
BTW, I believe that the 1.8 and 2.0 rocker arms are the same. Only the 1.7 rocker arms are different, and that's really only in the diameter of the adjuster. --DD |
Drums66 |
Jul 6 2013, 12:54 PM
Yes, you can. BTW, I believe that the 1.8 and 2.0 rocker arms are the same. Only the 1.7 rocker arms are different, and that's really only in the diameter of the adjuster. --DD .....I've done this several times with no problem's!! (IMG:style_emoticons/default/thumb3d.gif) (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) |
914Sixer |
Jul 6 2013, 04:34 PM
Why bother, they are the same rocker assembly UNLESS someone changed them out? 1.8 & 2.0 are 10mm adjustment screws. The 1.7 is a 8mm screw. The 1.7 rocker set up is the one to use if you are going for porsche swivel rockers.
Lo-Fi Version | Time is now: 13th May 2024 - 10:53 PM |
