Heat with Headers |
Heat with Headers |
rickso71 |
Dec 2 2004, 10:54 PM
Member Group: Members Posts: 74 Joined: 31-October 04 From: Derry, NH Member No.: 3,041 |
Is it possible to heat the windshield and passenger compartment in a car with headers? I wouldn't trust a gas heater but was thinking about stuffing a couple of 12V camping hair dryers in the heater ducts. Would probably only be a few hundred watts but might be enough for comfort in early spring and late fall.
Mueller |
Dec 2 2004, 11:13 PM
basicly, heat exchangers are headers, but with sheetmetal surrounding them to capture some of the heat
for a /4 motor, the h/e's are not the most efficient design flow wise, but they are more or less "headers" already aftermarket "headers" for the /4 motors are designed to weigh less and flow better.....add some ducting in a similar fashion and you have heat!!!!!! soem people have had success with electric heaters, do a search here, it's been brought up a gazillion time with what works and does not work and the +/-'s of them |
Trekkor |
Dec 2 2004, 11:24 PM
So, light guage steel in the form of a box with ducting and the blower moter could get it done?
KT |
MattR |
It was always my understanding that headers were an option for manifolds, and manifolds were cast. Is this true? Or am I oversimplifying?
Mueller |
Dec 2 2004, 11:48 PM
QUOTE(MattR @ Dec 2 2004, 10:24 PM) It was always my understanding that headers were an option for manifolds, and manifolds were cast. Is this true? Or am I oversimplifying? that is how I interpret it.....one single piece with multiple inlets/outlets is a manifold if you have seen the exhaust on a '75/76 1.8 or 2.0, I consider those to be exhaust manifolds that bolt to the head, those in turn are bolted to heat exchangers, but they are not headers....for a '74 and older car, the exhaust consists of a single pipes that converge at the muffler assembly....I really wouldn't consider them "headers" since their secondary function is to help provide heat...but they are a form of a modified header by "captureing" hot air surrounding the the tube(s), you have made a heat exchanger confused now?? hahahhaa |
McMark |
Dec 3 2004, 03:30 AM
Gas heaters get a bad wrap. <_<
ChrisFoley |
Dec 3 2004, 06:36 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
This link goes to my Tangerine Super Header page.
about 3/4 down to the bottom you will find the heat exchanger section. So, to answer your question, yes it is possible to heat the windshield and passenger compartment in a car with headers. |
ChrisFoley |
Dec 3 2004, 06:37 AM
QUOTE(markd@mac.com @ Dec 3 2004, 04:30 AM) Gas heaters get a bad wrap. (IMG:style_emoticons/default/dry.gif) I don't think there's anything wrong with gas heaters, but it would be hard to find a suitable installation location in a 914. |
Lo-Fi Version | Time is now: 16th May 2024 - 01:07 PM |
