Fuse panel SOLVED, Which ones go where?? |
dfelz |
Jul 17 2013, 03:04 PM
beach bum Group: Members Posts: 419 Joined: 7-June 12 From: San Diego Member No.: 14,538 Region Association: Southern California |
I am missing two fusses, and also have a few non stock ones in there that I don't know the rating of. Can someone please show me a picture with the stock colored fusses in there.
Thanks Attached thumbnail(s) |
monkeyboy |
Jul 17 2013, 03:20 PM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
Don't you still have the fuse panel picture you took?
I'll grab a photo of the fuse values and post it up for you. |
'73-914kid |
Jul 17 2013, 03:29 PM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
From left to right is...:
white, white, white, white, white, white, white, blue, white, white, white, blue. white fuses are 8 amp, and the blue ones are 25 amp |
green914 |
Jul 17 2013, 04:07 PM
Senior Member Group: Members Posts: 1,467 Joined: 29-March 11 From: Sacramento, California Member No.: 12,874 Region Association: Northern California |
(IMG:style_emoticons/default/confused24.gif) What year is your 914? From 1974 on they use 16 amp fuses in the spaces where 25 amp fuses go.
'73-914kid |
Jul 17 2013, 05:11 PM
'71 as per his signature
TheCabinetmaker |
Jul 17 2013, 06:31 PM
This is basic information that is included in most manuals
Along with a lot of other useful info. Buy your self a haynes manual. |
JeffBowlsby |
Jul 17 2013, 06:42 PM
914 Wiring Harnesses Group: Members Posts: 8,509 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Its not in the manuals - but Pelican has the correct fuses in their electrical tech references section.
Mblizzard |
Jul 17 2013, 07:18 PM
I had copied this from another post but I can't remember who to give credit for it.
Which fuse does what? Left to right, the fuses are numbered. 1 Left high beam 2 Right high beam 3 Left low beam 4 Right low beam 5 Left parking/running lights 6 Right parking/running lights 7 Taillights (including license plate lights) 8 Brake lights, horn, wipers, lighter 9 Power to gauges and G light (charging system), turn signals 10 Fog lights (if fitted) 11 Hazard lights 12 Headlight motors Fuses 8 and 12 are 25A, the rest are 8A. In later years, they dropped to 16A fuses for 8 and 12, and raised 10 to 16A, too. |
dfelz |
Jul 17 2013, 07:58 PM
From left to right is...: white, white, white, white, white, white, white, blue, white, white, white, blue. white fuses are 8 amp, and the blue ones are 25 amp perfect. No yellows anywhere? '71 as per his signature Thank you! This is basic information that is included in most manuals Along with a lot of other useful info. Buy your self a haynes manual. I checked my haynes first, as always i always do before bothering to post, wasn't there... I dont own an OEM manual, just a laptop with access to this forum (IMG:style_emoticons/default/biggrin.gif) Thanks for the help guys! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 05:18 PM |
