My first 914 joys, woes, and discoveries., My newly acquired 914 saw pavement for the first time in four years |
dvid3k |
Jul 29 2013, 04:54 PM
Newbie Group: Members Posts: 31 Joined: 22-July 13 From: Charleston WV Member No.: 16,146 Region Association: None |
I'll be updating this post as I work and learn my way around my first 914.
I posted an introductory thread back when I joined, this is for my updates and observations. I've received quite a warm welcome and I've learned a lot from this forum already. I'm amazed at how helpful members are, I definitely appreciate any advice I have received thus far. A week ago I purchased my first 914 project car (72 914 Chalon) and during the past week I've been getting it back up and running, a task that has involved a little blood, sweat and possibly a few tears. (thanks to a pry bar to the finger) (IMG:style_emoticons/default/headbang.gif) The car had been sitting for several years, at least since 2009, possibly longer, several inches deep in mud it sat at the corner of a mechanics garage where it seemed to have been dropped off several years ago. I installed a new fuel pump, replaced rubber lines, removed and cleaned out fuel tank, repaired the accelerator bracket, changed the oil cleaned up the floor under the seats. I've now got the car running and today I took it out on my road for a test drive to see what else needed attention. So far I've found the following: 1. Tach does not work 2. Odometer does not work 3. Front suspension feels very loose and bouncy when going over bumps. 4. Throttle cable is a bit rough 5. Shifting will definitely take me a while to get used to, (tail shift) I will be thrilled to get the car back in good working order, but I've got my work cut out for me. I washed it up once already but It'll take a few more washes to get 4 years of gunk off. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1340.photobucket.com-16146-1375140871.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1340.photobucket.com-16146-1375140872.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1340.photobucket.com-16146-1375140872.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1340.photobucket.com-16146-1375140872.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1340.photobucket.com-16146-1375140872.5.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1340.photobucket.com-16146-1375140872.6.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1340.photobucket.com-16146-1375140872.7.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1340.photobucket.com-16146-1375140873.8.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1340.photobucket.com-16146-1375140873.9.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1340.photobucket.com-16146-1375140873.10.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1340.photobucket.com-16146-1375140873.11.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1340.photobucket.com-16146-1375140873.12.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1340.photobucket.com-16146-1375140873.13.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1340.photobucket.com-16146-1375140874.14.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1340.photobucket.com-16146-1375140874.15.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1340.photobucket.com-16146-1375140874.16.jpg) |
dvid3k |
Aug 30 2013, 07:03 PM
I finished up the car rebuild today and got them back on the car and I'm already feeling a world of difference, the throttle response is about 200% better and I also fixed my binding accelerator issue by fixing the linkage between the two carbs, it was binding and making the throttle pedal stick. The car runs much better but I can feel that it isn't running as smooth as it should, I think I'm going to be taking my fuel take to have it flushed and coated so while I'm doing that I'll see about getting the carbs tuned up, it'll be my first time so it will definitely be a learning experience. The floats were way off when I took the carbs apart but that is just one thing in the long list of things that have been wrong from the start. I don't think I've ran into one thing on this car that has been set up right.
cwpeden |
Aug 30 2013, 07:33 PM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
I finished up the car rebuild today and got them back on the car and I'm already feeling a world of difference, the throttle response is about 200% better and I also fixed my binding accelerator issue by fixing the linkage between the two carbs, it was binding and making the throttle pedal stick. The car runs much better but I can feel that it isn't running as smooth as it should, I think I'm going to be taking my fuel take to have it flushed and coated so while I'm doing that I'll see about getting the carbs tuned up, it'll be my first time so it will definitely be a learning experience. The floats were way off when I took the carbs apart but that is just one thing in the long list of things that have been wrong from the start. I don't think I've ran into one thing on this car that has been set up right. You'll need one of these: goes in the bottom of the tank. Because this will stop fuel flow too: |
dvid3k |
Aug 31 2013, 07:46 AM
I finished up the car rebuild today and got them back on the car and I'm already feeling a world of difference, the throttle response is about 200% better and I also fixed my binding accelerator issue by fixing the linkage between the two carbs, it was binding and making the throttle pedal stick. The car runs much better but I can feel that it isn't running as smooth as it should, I think I'm going to be taking my fuel take to have it flushed and coated so while I'm doing that I'll see about getting the carbs tuned up, it'll be my first time so it will definitely be a learning experience. The floats were way off when I took the carbs apart but that is just one thing in the long list of things that have been wrong from the start. I don't think I've ran into one thing on this car that has been set up right. You'll need one of these: goes in the bottom of the tank. Because this will stop fuel flow too: I looked into one of those after I read about them but after looking at my tank it seems like someone has modified the outlets by brazing them on when they did the conversion to carbs so at least for now it looks like adding a extra fuel filter in the line is about my only option. |
Lo-Fi Version | Time is now: 15th May 2024 - 07:33 PM |
