What is the physical location of the wiper relay?-RESOLVED, Without the intermittent option, there is no relay |
HalfMoon |
Aug 1 2013, 07:42 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
I'm still waiting for my manual to come in the mail and the schematic doesn't state where the physical location of the wiper relay. To check if it's wired correctly according to the schematic I need to know where the relay should be located as I'm new to the 914. This was recently purchased and the PO made some significant modifications.
What I need to know at this point is where should the relay physically is located on the car? This is a 1973 non-intermittent wiper 914. |
Mike Bellis |
Aug 1 2013, 07:52 PM
I'm still waiting for my manual to come in the mail and the schematic doesn't state where the physical location of the wiper relay. To check if it's wired correctly according to the schematic I need to know where the relay should be located as I'm new to the 914. This was recently purchased and the PO made some significant modifications. What I need to know at this point is where should the relay physically is located on the car? This is a 1973 non-intermittent wiper 914. There is no relay. The wipers work directly from the switch. There is only a relay if you have intermittent wipers. |
HalfMoon |
Aug 1 2013, 08:02 PM
I'm still waiting for my manual to come in the mail and the schematic doesn't state where the physical location of the wiper relay. To check if it's wired correctly according to the schematic I need to know where the relay should be located as I'm new to the 914. This was recently purchased and the PO made some significant modifications. What I need to know at this point is where should the relay physically is located on the car? This is a 1973 non-intermittent wiper 914. There is no relay. The wipers work directly from the switch. There is only a relay if you have intermittent wipers. Thank you alot! Huge help (IMG:style_emoticons/default/beer.gif) That greatly clarifies a confusing point. In another thread where I'm trying to make my wipers work an image was posted of the schematic for the wiper and it included a relay which I've been trying to find all over the car. Obviously (in hindsight) that image was for the application with the optional intermittent system. Now I'm armed with information that I can make to good use first thing in the morning :-) |
Mike Bellis |
Aug 1 2013, 08:28 PM
The wiper switch and motor are shown here between 4-9.
To read this: Grounds are at the bottom. There is a yellow numbering system below. If you are following a wire and it stops at a number inside a square, go to that number in yellow to find the other side of the wire. If multiple grounds have the same number in a circle, that means they are connected to the same point. Download and save this... |
HalfMoon |
Aug 1 2013, 09:10 PM
The wiper switch and motor are shown here between 4-9. To read this: Grounds are at the bottom. There is a yellow numbering system below. If you are following a wire and it stops at a number inside a square, go to that number in yellow to find the other side of the wire. If multiple grounds have the same number in a circle, that means they are connected to the same point. Download and save this... I saw this on there web page but didn't think it would apply to me as mines a 73. Jeff B says they changed alot of wiring stuff from year to year. Do you think this would apply to a 73? |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:42 PM |
