Should I worry about shrinkage?, Replacing rear half of floor pan(s) |
motorvated |
Aug 6 2013, 06:44 AM
Member Group: Members Posts: 279 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
The rear half of the drivers side floor pan of my 72 is rusted and has been poorly repaired. Before I start cutting into it and welding a new panel in place with my gas shielded wire feed MIG, can anyone tell me if and how I should brace the car so I won't screw up things like the door fender gaps, or shouldn't I worry about it since I'm not touching the longs. The car presently is on jack stands, as most seem to be! Thanks, Mike.
76-914 |
Aug 6 2013, 08:28 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,503 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Just go slow. If the metal is cool enough to touch your alright. Don't concentrate too much in one area. Move around with the welds and cool with an air hose as you go. I did my longs this way w/o bracing. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 19th May 2024 - 12:58 PM |
