Door check strap clicks, any solutions? |
914ltd |
Aug 11 2013, 08:25 PM
Member Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
A real common 914 problem: The tabs mounted on the door post have worn and allow the new check strap to click as it reaches the next detent. A larger pin would eliminate the problem but enlarging the holes on the tabs is a problem with clearance issues. Any bright ideas? Thanks, Brad
Attached image(s) |
partwerks |
Aug 18 2013, 09:44 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Brad,
Would clamping a piece of brass over the hole and spot welding it shut, and re drilling it to the correct size, work?? |
914ltd |
Aug 19 2013, 06:22 AM
Lo-Fi Version | Time is now: 26th May 2024 - 08:56 AM |
