Door check strap clicks, any solutions? |
914ltd |
Aug 11 2013, 08:25 PM
Member Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
A real common 914 problem: The tabs mounted on the door post have worn and allow the new check strap to click as it reaches the next detent. A larger pin would eliminate the problem but enlarging the holes on the tabs is a problem with clearance issues. Any bright ideas? Thanks, Brad
Attached image(s) |
Firstcar |
Aug 19 2013, 07:02 AM
Obsessive amateur mechanic Group: Members Posts: 98 Joined: 17-March 11 From: MA -South Shore Member No.: 12,831 Region Association: North East States |
I used a short bolt with a nylon nut in place of the pin. The bolt was large enough diameter to fill the hole in the stay (1/4"?) and just long enough to secure a nylon nut underneath the tabs. Easy to install and tighten. I tightened the nut just enough to stop the stay from moving and clicking. Not stock, but works great and is reversible.
Lo-Fi Version | Time is now: 26th May 2024 - 02:19 AM |
