Engine's out again, problem found..., previous post about compression leak.. |
Mike D. |
Dec 9 2004, 12:04 AM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
So, this past weekend I dropped the 6 to look for a compression leak on the number three cylinder. As soon as the cooling shroud came off it didn't take long to find it.
It doesn't look too bad and now I will finally know for sure what pistons and cams I have. Also have to take care of an oil leak on the front somewhere. (or rear depending on what car or book (IMG:style_emoticons/default/smile.gif) ) Check it out. Attached thumbnail(s) |
Mike D. |
Dec 9 2004, 12:05 AM
here's the close up #3
Mike D. |
Dec 9 2004, 12:06 AM
compared to the others
cnavarro |
Dec 9 2004, 11:33 AM
Cylinder Guru Group: Members Posts: 472 Joined: 30-December 02 From: Chicagoland! Member No.: 49 Region Association: None |
Is that a 2.0? See the nice rusty barrels :-)
Charles Navarro LN Engineering http://www.LNengineering.com Aircooled Precision Performance |
Series9 |
Dec 9 2004, 12:22 PM
Wow. I thought it was the head gasket, but damn. Well, get in there...
cnavarro |
Dec 9 2004, 12:26 PM
If it is a 2.0, that "head gasket" really doesn't help seal against that level of leakage, it's just more to reduce the combusion by-products getting blown into the stale air heat, or at least that's what I was told by an engine builder who does lots of 2.0 race engines.
J P Stein |
Dec 9 2004, 02:40 PM
QUOTE(cnavarro @ Dec 9 2004, 10:26 AM) If it is a 2.0, that "head gasket" really doesn't help seal against that level of leakage, it's just more to reduce the combusion by-products getting blown into the stale air heat, or at least that's what I was told by an engine builder who does lots of 2.0 race engines. Charles Navarro LN Engineering http://www.LNengineering.com Aircooled Precision Performance Yes, the head gasket of a SB chebbie won't seal that level of leakage, either. It's just more there to keep the combustion products out of the water jackets. I read this somewhere, but may have lost something in the translation. |
sixnotfour |
Dec 9 2004, 03:10 PM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Unless it has to be 2.0 , Get some 2.2-2.4 heads and cylinders.gotta have 2.2 pistons for comp. if its short stroke still
Bigger valves, better head gasket ,more CC's Mag case witth 66 dated heads, its been around . mag late 68 (IMG:style_emoticons/default/beerchug.gif) |
Mike D. |
Dec 9 2004, 04:50 PM
Case is a 1970 2.2, everything else is earlier. I'll post more pics this weekend after the heads come off. And if they are still 2.0 p/c's, then 2.2's will be going back on.
A couple of things bug me about this leak. Two different Pro Porsche mechanics diagnosed the noise as something completely different. One of the guys here that told me it might be a vac leak (closer). It was the very same day (the last so cal fun run) that it blew out for good. |
sixnotfour |
Dec 10 2004, 05:20 AM
Maybe it still has 2.2 Cylinders and someone cut the heads to accept the 2.2/2.4 stlye cylinders and did a poor machining operation. Heads have different thinkness. (blown head gasket)
Kinda scarey about the diagnossis you got. Know you'll know what you got. |
Kerrys914 |
Dec 10 2004, 09:40 AM
Mike, do you have any rubber vibration isolation pieces between the engine mount bar and the body mount?
Have any photos? |
Mike D. |
Dec 10 2004, 01:43 PM
QUOTE(Kerrys914 @ Dec 10 2004, 07:40 AM) Mike, do you have any rubber vibration isolation pieces between the engine mount bar and the body mount? Have any photos? I'm using the stock 911 enging mounts. They are round with a rubber center similar to the 914 Trans mount. (but not).. They work great, and fit perfectly in the 914 engine mount space. see pic... Attached image(s) |
Root_Werks |
Dec 10 2004, 03:09 PM
Village Idiot Group: Members Posts: 8,319 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Yep, I am using the same mounts on the front of my 914-6 with a cross bar. Kerry, make sure you also get the big washers that go on top of these. They fit and work great. Like they were made for the 914. (IMG:style_emoticons/default/biggrin.gif)
Kerrys914 |
Dec 10 2004, 07:21 PM
Do the washers come withi t or are they listed seperatly? I see the mounts listed on PParts..I'll check for the washers too.
Cheers |
Mike D. |
Dec 12 2004, 11:33 PM
got the heads off today. The head gasket was totally blown out of one corner. the engine also had two different brands of head gasket. What the?? It's also a confirmed 2 liter. 80mm p/c's. Valves: intake 39mm, exhaust 35mm. So nothing special there. I pulled out one of the cams to check part number, and I'm not sure what I've got maybe someone can shed some light. Part #901.105.139 OR... I found the number on this carquip web site and it says 911L, but I did not find anything listed as 911L in Bruce Andersons book. I have 3 distributers, T, E & S, and need to know which one is best suited to this cam.
I also found lot's of carbon, probably more than I should have.. <_< check it out... -Mike D. Attached thumbnail(s) |
Mike D. |
Dec 12 2004, 11:35 PM
close up pistons
Mike D. |
Dec 12 2004, 11:36 PM
different head gasket
Mike D. |
Dec 12 2004, 11:37 PM
inside the heads...
Mike D. |
Dec 12 2004, 11:38 PM
the cam, can sort of see the part number.
Aaron Cox |
Dec 12 2004, 11:39 PM
mike..it sounded good on the funrun! sorry to see it apart (IMG:style_emoticons/default/sad.gif)
Lo-Fi Version | Time is now: 13th May 2024 - 08:05 AM |
