Fuel starve in AX sweepers, tech fix other than "add more gas"? |
Chris Pincetich |
Aug 19 2013, 01:34 PM
So this Saturday I dusted off the 914 and did an AX race after more than a year of being "too busy" w my great job at www.seaturtles.org
(IMG:style_emoticons/default/driving.gif) I've ALWAYs shown up to the AX w less than a quarter tank of gas. I have a 1972 1.7 w stock D-jet and aftermarket intake and exhaust. Stock fuel pump, OE low rear mounted, stock gas tank and lines but with evap system on top of fuel tank completely removed (recently). So, on runs 2-5 I get a period of "no power" after each of the long, fast sweeping left and right turns. Ok, either I have a fuel problem, or ignition. All wires solid, so I drive out and get 4 gallons of gas. More gas = Problem solved! (IMG:style_emoticons/default/beerchug.gif) I'm posting because I used to always do AX races w barely any gas and have never had this problem. Any ideas on why I had this problem? Fixes to improve for next time? Thanks! (IMG:style_emoticons/default/beerchug.gif) |
Woody |
Aug 19 2013, 02:20 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
So this Saturday I dusted off the 914 and did an AX race after more than a year of being "too busy" w my great job at www.seaturtles.org (IMG:style_emoticons/default/driving.gif) I've ALWAYs shown up to the AX w less than a quarter tank of gas. I have a 1972 1.7 w stock D-jet and aftermarket intake and exhaust. Stock fuel pump, OE low rear mounted, stock gas tank and lines but with evap system on top of fuel tank completely removed (recently). So, on runs 2-5 I get a period of "no power" after each of the long, fast sweeping left and right turns. Ok, either I have a fuel problem, or ignition. All wires solid, so I drive out and get 4 gallons of gas. More gas = Problem solved! (IMG:style_emoticons/default/beerchug.gif) I'm posting because I used to always do AX races w barely any gas and have never had this problem. Any ideas on why I had this problem? Fixes to improve for next time? Thanks! (IMG:style_emoticons/default/beerchug.gif) switch to carbs. (IMG:style_emoticons/default/poke.gif) |
Randal |
Aug 19 2013, 06:20 PM
Slosh boxes and foam work great. |
Aug 19 2013, 08:18 PM
Resident German Group: Admin Posts: 41,623 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
PlaysWithCars |
Aug 19 2013, 09:39 PM
Senior Member Group: Members Posts: 524 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/lol-2.gif) |
Racer |
Aug 20 2013, 07:56 PM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
Um, don't run sticky tires? (IMG:style_emoticons/default/wink.gif)
fwiw, I couldn't run below 1/4 tank in my '70 w/o starvation problems. I just ran 1/4-1/3 tank. An extra gallon or two sure prevents frustration and slower times despite any weight penalty. |
McMark |
Aug 21 2013, 09:23 AM
For AX you could probably get away with mounting a small fuel cell in the front trunk with a selector valve to shut off the main tank.
Like this one. |
brant |
Aug 21 2013, 01:26 PM
914 Wizard Group: Members Posts: 11,620 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
fuel accumulators work wonders too....
I haven't really heard much of a problem with stock stuff in autox though surprised (But perhaps I'm misinformed) that your having this problem |
Chris Pincetich |
Aug 21 2013, 01:51 PM
I haven't really heard much of a problem with stock stuff in autox though surprised (But perhaps I'm misinformed) that your having this problem Me too! (IMG:style_emoticons/default/beerchug.gif) Over a dozen races w no issues and always w very little fuel More testing is needed Best check my local AX calendar and go racin again (IMG:style_emoticons/default/driving.gif) I have fun, but it's kinda depressing being on the back half of the standings. If only PAX was horsepower alone, it'd be top 10 since I have ~90 HP (IMG:style_emoticons/default/laugh.gif) |
ChrisFoley |
Aug 22 2013, 06:33 PM
I am Tangerine Racing Group: Members Posts: 7,922 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I haven't really heard much of a problem with stock stuff in autox though surprised (But perhaps I'm misinformed) that your having this problem Me too! (IMG:style_emoticons/default/beerchug.gif) Over a dozen races w no issues and always w very little fuel More testing is needed Best check my local AX calendar and go racin again (IMG:style_emoticons/default/driving.gif) I have fun, but it's kinda depressing being on the back half of the standings. If only PAX was horsepower alone, it'd be top 10 since I have ~90 HP (IMG:style_emoticons/default/laugh.gif) I always ran an accumulator when I road raced with a d-jet injected engine. Low pressure pump to keep a 1 quart cylinder filled with fuel and the stock FI pump to deliver fuel to the engine. Overflow from the FI system went back to the accumulator and a top fitting on the accumulator returned any excess to the fuel cell (tank). |
grantsfo |
Aug 22 2013, 08:02 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
My Z has four scavenger pumps feeding an accumulator. Fuel starve what's that? I never ran less than 1/4 tank in my stock 914 tank - the weight up there in ax is good too!
Aug 27 2013, 12:02 PM
So this Saturday I dusted off the 914 and did an AX race after more than a year of being "too busy" w my great job at www.seaturtles.org (IMG:style_emoticons/default/driving.gif) Old fuel. QUOTE So, on runs 2-5 I get a period of "no power" after each of the long, fast sweeping left and right turns. Ok, either I have a fuel problem, or ignition. All wires solid, so I drive out and get 4 gallons of gas. More gas = Problem solved! (IMG:style_emoticons/default/beerchug.gif) Fuel filter replacement time. |
dlestep |
Oct 3 2013, 08:01 PM
I am smilin'... Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
I know that this was awhile back, but I was compelled to respond.
With fuel starvation problems, one might look to the off-road endurance setups. In the 80's, a simple change to the carbs was the way to go. The floats were removed and a plate added to cap-off 90% of the bowl. I ran two pumps, one pressurizing the bowls, the other scavaging / fuel return. or fuel injection, mechanical or electrical. |
Heater Guy |
Oct 4 2013, 02:46 PM
Member Group: Members Posts: 74 Joined: 20-October 09 From: Walnut Creek, CA Member No.: 10,960 Region Association: Northern California |
Attached is a photo of a fuel collector. The low pressure fuel pump is always scavenging fuel from the tank and pumping it into the one quart container. On top of the container is a line back to the fuel tank. This keeps the container full. The high pressure or another pump supplies fuel to the fuel injectors or carbs. This system prevents fuel starvation no matter how much cornering you do. I can run my tank down to 1 gal.and never have a problem. This system is used on many hard corning cars like Toyota Atlantics and D Sport Roadsters.
Lo-Fi Version | Time is now: 5th May 2024 - 08:17 PM |
