Valve Clearance? |
Valve Clearance? |
last337 |
Aug 19 2013, 02:33 PM
Member Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None |
Can someone explain this to me? I have been fighting with this thing for some time now. I had so many problems for so long with my engine just dying and after pulling my tank and changing fuel lines and filters I am back running again.
Now I am having another issue where I will get my dual carbs tuned just right at operating temp and be running just fine. However, after a while I start to hear backfiring again. The only thing I havent done in a while is set my valve clearances. Actually it has been a long while since I have done that and I am suspicious about it being the culprit. I understand how if my timing was off or my mixture was off I could hear pinging or backfiring through the exhaust. But I dont know why my valve clearance would do that only as the temp of the engine changes or just seemingly by itself at times. Can someone explain how proper valve clearance is so critical? |
Lo-Fi Version | Time is now: 16th May 2024 - 09:39 PM |
