CptTripps' Restoration 2 - The Grey Matter Build, Back in Doug’s garage |
CptTripps |
Aug 19 2013, 03:00 PM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
Hey gang!
I'm back in the mix, and getting ready for another 914 restoration. Not sure this will play out as well as it did Last Time, but we'll give her a go and see what I can come up with! After I find the right starting-point, here's what I've been dreaming of doing to it. Subaru EJ20 Turbo 4 engine & Trans. (250-275hp target) Steel flares 5-bolt hubs Boxster brakes Stiffen up the body. (MAYBE a roll-bar.) Satin silver paint, blacked-out chrome, black satin rims...with colorful calipers. I think I've found the right starting-point car (70-1.7 with carbs) so I'll drive it a bit while I'm stock-piling parts. That way I can start the project in earnest this winter while the snow falls. I'm going to use the 901 side-shift trans I have in my basement to mount up to the EJ20 after I can locate a decent one. That way, I should be able to get everything right and then mount it up a lot easier after I drop the 1.7 out. (Best intentions...always lead to disappointment, but I'll try anyway.) Things I learned the last time: * Do the body work all the way up to the primer, then let a pro take it from there. * It's much easier to work when you have a lot of light. * Garage heaters are your friend. * When in doubt...STOP and look for an answer. (Doubling your bad efforts never works.) * Wearing those blue latex gloves alleviates embarrassing situations in meetings * The search button is your friend. (Spelling is also...thanks Andy.) Here we go! UPDATE: I ended up with a 1975 with a V8 conversion as a starting point. UPDATE 2: The engine I found had a good Trans on it, so I'm going to have a Subaru 5MT not a 901. UPDATE 3: 350 is my new HP goal UPDATE 4: I'm naming the project "Grey Matter" because the car is going to be a lot more than just a restoration. That...and project names are cool. (IMG:style_emoticons/default/biggrin.gif) UPDATE 5: April 17th is the "due date" to have it complete. Not as fast as my last build, but there is a LOT more to this one. |
Chris H. |
Aug 19 2013, 06:21 PM
Senior Member Group: Members Posts: 4,028 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Any 5MT will bolt up but you should look for one that was mated to a "turbo" car. The newer the better is the rule. Mine is from a stock 2006 WRX that had a 2.5T in it. I bolted it to a 3.3L SVX engine. Haven't driven it yet but it LOOKS REALLY GOOD!
Someone else will chime in on the engine piece I'm sure. EDIT: Get the ECU and engine wiring harness for sure. Here's a thread you might want to check out. ON A PRIVATE ROAD some guy was embarassing kids in their Mustangs and GTOs with his lowly 914 2.0T. I'm sure it wasn't DBCooper though...he was just taping it. Note how quickly the 914 pulls away... Link |
CptTripps |
Aug 19 2013, 09:49 PM
Any 5MT will bolt up but you should look for one that was mated to a "turbo" car. The newer the better is the rule. Mine is from a stock 2006 WRX that had a 2.5T in it. I bolted it to a 3.3L SVX engine. Haven't driven it yet but it LOOKS REALLY GOOD! The idea of a bigger power plant is fun and all, but I've always been a fan of a 4-cyl turbo. I'm not going to be tracking the car at all, so the gain in HP for tooling around with one of my boys is what I'm aiming for. 3.3 would be a bit of overkill for...me anyway. Just purchased the Boxster calipers and the adapters from Rich. Ordered the rear 1/2 of the floor pan, and Flares from AA. Looks like I'll be picking the car up Wed night to drive home. Should be fun! |
Lo-Fi Version | Time is now: 26th April 2024 - 01:45 AM |
