CptTripps' Restoration 2 - The Grey Matter Build, Back in Doug’s garage |
CptTripps |
Aug 19 2013, 03:00 PM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
Hey gang!
I'm back in the mix, and getting ready for another 914 restoration. Not sure this will play out as well as it did Last Time, but we'll give her a go and see what I can come up with! After I find the right starting-point, here's what I've been dreaming of doing to it. Subaru EJ20 Turbo 4 engine & Trans. (250-275hp target) Steel flares 5-bolt hubs Boxster brakes Stiffen up the body. (MAYBE a roll-bar.) Satin silver paint, blacked-out chrome, black satin rims...with colorful calipers. I think I've found the right starting-point car (70-1.7 with carbs) so I'll drive it a bit while I'm stock-piling parts. That way I can start the project in earnest this winter while the snow falls. I'm going to use the 901 side-shift trans I have in my basement to mount up to the EJ20 after I can locate a decent one. That way, I should be able to get everything right and then mount it up a lot easier after I drop the 1.7 out. (Best intentions...always lead to disappointment, but I'll try anyway.) Things I learned the last time: * Do the body work all the way up to the primer, then let a pro take it from there. * It's much easier to work when you have a lot of light. * Garage heaters are your friend. * When in doubt...STOP and look for an answer. (Doubling your bad efforts never works.) * Wearing those blue latex gloves alleviates embarrassing situations in meetings * The search button is your friend. (Spelling is also...thanks Andy.) Here we go! UPDATE: I ended up with a 1975 with a V8 conversion as a starting point. UPDATE 2: The engine I found had a good Trans on it, so I'm going to have a Subaru 5MT not a 901. UPDATE 3: 350 is my new HP goal UPDATE 4: I'm naming the project "Grey Matter" because the car is going to be a lot more than just a restoration. That...and project names are cool. (IMG:style_emoticons/default/biggrin.gif) UPDATE 5: April 17th is the "due date" to have it complete. Not as fast as my last build, but there is a LOT more to this one. |
CptTripps |
Aug 31 2013, 12:44 PM
Parts fairy showed up today...with a great delivery from the ATL.
Steel Flairs Rear Chassis Stiffening Kit GT Rockers ...still don't have the car. (IMG:style_emoticons/default/dry.gif) Attached thumbnail(s) |
914forme |
Sep 5 2013, 09:42 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Parts fairy showed up today...with a great delivery from the ATL. Steel Flairs Rear Chassis Stiffening Kit GT Rockers ...still don't have the car. (IMG:style_emoticons/default/dry.gif) Rear stiffening kit does not do a lot for you. I hate to say. Order a Log kit for 914ltd. It adds some weight to the car, but is makes it super stiff. runs the entire log. Then add a brace to the rear suspension arms. Thats about as good as it gets unless you also run up the inner log. I still added a roll bar and a petty bar, but the car is super stiff with out the bars. I have the GT stiffening kit in also, so don't feel to bad about it. BTW, thanks for the tip on the Solstice mirrors, I saw them on the Anklebitter and always thought cool. Never knew they where so cheap. And where did you get the caps from? I have a set of 18' Cayman S wheels I need caps for. |
Lo-Fi Version | Time is now: 18th April 2024 - 05:03 PM |
