CptTripps' Restoration 2 - The Grey Matter Build, Back in Doug’s garage |
CptTripps |
Aug 19 2013, 03:00 PM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
Hey gang!
I'm back in the mix, and getting ready for another 914 restoration. Not sure this will play out as well as it did Last Time, but we'll give her a go and see what I can come up with! After I find the right starting-point, here's what I've been dreaming of doing to it. Subaru EJ20 Turbo 4 engine & Trans. (250-275hp target) Steel flares 5-bolt hubs Boxster brakes Stiffen up the body. (MAYBE a roll-bar.) Satin silver paint, blacked-out chrome, black satin rims...with colorful calipers. I think I've found the right starting-point car (70-1.7 with carbs) so I'll drive it a bit while I'm stock-piling parts. That way I can start the project in earnest this winter while the snow falls. I'm going to use the 901 side-shift trans I have in my basement to mount up to the EJ20 after I can locate a decent one. That way, I should be able to get everything right and then mount it up a lot easier after I drop the 1.7 out. (Best intentions...always lead to disappointment, but I'll try anyway.) Things I learned the last time: * Do the body work all the way up to the primer, then let a pro take it from there. * It's much easier to work when you have a lot of light. * Garage heaters are your friend. * When in doubt...STOP and look for an answer. (Doubling your bad efforts never works.) * Wearing those blue latex gloves alleviates embarrassing situations in meetings * The search button is your friend. (Spelling is also...thanks Andy.) Here we go! UPDATE: I ended up with a 1975 with a V8 conversion as a starting point. UPDATE 2: The engine I found had a good Trans on it, so I'm going to have a Subaru 5MT not a 901. UPDATE 3: 350 is my new HP goal UPDATE 4: I'm naming the project "Grey Matter" because the car is going to be a lot more than just a restoration. That...and project names are cool. (IMG:style_emoticons/default/biggrin.gif) UPDATE 5: April 17th is the "due date" to have it complete. Not as fast as my last build, but there is a LOT more to this one. |
strawman |
Sep 21 2013, 10:44 PM
Senior Member Group: Members Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
As someone who has done the trailing arm reinforcements you have pictured above, I'd like to suggest you scrap that idea -- it makes 'em uber-heavy. Eric Shea's notion of welding in tubes laterally makes a lot more sense (I shamelessly copied his idea!). Not sure he's still providing that service, but it is much lighter; I ended up practically giving away the "clam-shelled" trailing arms.
Good luck with your project; you're making way better progress than I. I am almost five years into my turbo'd Suby project and keep getting sidetracked with other projects... |
CptTripps |
Sep 23 2013, 06:37 AM
As someone who has done the trailing arm reinforcements you have pictured above, I'd like to suggest you scrap that idea -- it makes 'em uber-heavy. Quick question on this: The reinforcements only weigh about 2-lb each. Does it really add that much weight? IIRC, those are about 15-18lb to begin with. Does another 2-ish change things that much? |
rick 918-S |
Sep 23 2013, 08:29 AM
Hey nice rack! -Celette Group: Members Posts: 20,409 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
As someone who has done the trailing arm reinforcements you have pictured above, I'd like to suggest you scrap that idea -- it makes 'em uber-heavy. Quick question on this: The reinforcements only weigh about 2-lb each. Does it really add that much weight? IIRC, those are about 15-18lb to begin with. Does another 2-ish change things that much? It's all un-sprung weight. The worst kind to add. |
CptTripps |
Sep 23 2013, 08:39 AM
It's all un-sprung weight. The worst kind to add. Gotcha. I guess that makes sense. QUOTE(badmiata @ Sep 23 2013, 09:27 AM) Really love your progress!!! Thanks...although it doesn't seem like I'm getting anywhere just yet. Gotta get him on jack-stands so I can really start cranking. I feel like if I took a week off work and just powered through, I could get a lot further. But then I think "If I finish too early, I'll just be pissed that the car is done, and I can't drive it in the snow." |
Lo-Fi Version | Time is now: 20th April 2024 - 09:17 AM |
