CptTripps' Restoration 2 - The Grey Matter Build, Back in Doug’s garage |
CptTripps |
Aug 19 2013, 03:00 PM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
Hey gang!
I'm back in the mix, and getting ready for another 914 restoration. Not sure this will play out as well as it did Last Time, but we'll give her a go and see what I can come up with! After I find the right starting-point, here's what I've been dreaming of doing to it. Subaru EJ20 Turbo 4 engine & Trans. (250-275hp target) Steel flares 5-bolt hubs Boxster brakes Stiffen up the body. (MAYBE a roll-bar.) Satin silver paint, blacked-out chrome, black satin rims...with colorful calipers. I think I've found the right starting-point car (70-1.7 with carbs) so I'll drive it a bit while I'm stock-piling parts. That way I can start the project in earnest this winter while the snow falls. I'm going to use the 901 side-shift trans I have in my basement to mount up to the EJ20 after I can locate a decent one. That way, I should be able to get everything right and then mount it up a lot easier after I drop the 1.7 out. (Best intentions...always lead to disappointment, but I'll try anyway.) Things I learned the last time: * Do the body work all the way up to the primer, then let a pro take it from there. * It's much easier to work when you have a lot of light. * Garage heaters are your friend. * When in doubt...STOP and look for an answer. (Doubling your bad efforts never works.) * Wearing those blue latex gloves alleviates embarrassing situations in meetings * The search button is your friend. (Spelling is also...thanks Andy.) Here we go! UPDATE: I ended up with a 1975 with a V8 conversion as a starting point. UPDATE 2: The engine I found had a good Trans on it, so I'm going to have a Subaru 5MT not a 901. UPDATE 3: 350 is my new HP goal UPDATE 4: I'm naming the project "Grey Matter" because the car is going to be a lot more than just a restoration. That...and project names are cool. (IMG:style_emoticons/default/biggrin.gif) UPDATE 5: April 17th is the "due date" to have it complete. Not as fast as my last build, but there is a LOT more to this one. |
CptTripps |
Oct 14 2013, 12:53 PM
Alright Mark...I'm in the garage!
Got to the "Donor WRX" today to start pulling stuff. I have NO idea how much of the wiring harness I'll need, so I just grabbed all of it. Every inch of wire from the entire car. I'm sure it's overkill, but I'd rather have more than not enough. Ian told me last week "do yourself a favor and just send the wiring harness off to Small Car Performance" and I think I'm A-OK with that, after seeing the magnitude of what is needed for the wiring. There's 60LB of stuff here, and I'll bet I get 10lb back. Also have most of the engine out of it. We just sawzalled the front clip so we could get a little deeper into it without restriction. I should have everything off in a week or so as I get closer to pulling the V8 out of my 914. I'm toying with the idea of having someone else re-build the motor. Just to be on the safe side. I'd rather KNOW I'm starting with something that's solid. Besides, now is the time...right? I can also put some upgrades inside and add a few HPs in the meantime. So...that's a little progress. Right? Attached thumbnail(s) |
Lo-Fi Version | Time is now: 23rd April 2024 - 05:10 AM |
