Paul's stock six conversion |
914itis |
Aug 19 2013, 05:51 PM
As some of you may know already, I picked up an original 914-6 motor and will be replacing my 2.0l 4. on my phoenix red
I know ths s not a big 3.2, but this s a cool upgrade for me. So far I have located all the extra components to complete this conversion. Engine tins headers muffler - triad oil cooler oil tank -Velios with filler neck and dipstick bell crank for transmission to carbs I will be looking for the oil lines. If I am missing anything please give me your expertise. A picture or oil lines diagram will be helpful. The first thing i would like to do is bench test it. As always, all advices are welcome and appreciated Related thread Related thread Thanks Paul (IMG:style_emoticons/default/wub.gif) |
Cairo94507 |
Aug 19 2013, 06:05 PM
Michael Group: Members Posts: 9,822 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Very cool and exciting. Looking forward to following the work as it progresses. Have fun.
Porschef |
Aug 19 2013, 07:17 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
I don't think it's gonna work. Besides, I don't think it's gonna fit.
Get rid of it |
Aug 19 2013, 07:22 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Bench test it with the oil tank attached correctly, and make sure the tank is at the correct height.
Then, spin the motor without plugs to get oil into the motor first, then put in the plugs and fire it up. |
914itis |
Aug 19 2013, 07:27 PM
Joe,
I know it will fit on yours. Come and get it, you are only 45 miles away Rich, thanks for the advise, what kind of oil should I use in this? Still brad-penn? |
Porschef |
Aug 19 2013, 07:34 PM
Really, that's sweet. Enjoyed the looks of all the folks doing double takes on the parkway w two teeners buzzing by...
Aug 19 2013, 09:02 PM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
As some of you may know already, I picked up an original 914-6 motor and will be replacing my 2.0l 4. on my phoenix red I know ths s not a big 3.2, but this s a cool upgrade for me. So far I have located all the extra components to complete this conversion. Engine tins headers muffler - triad oil cooler oil tank -Velios with filler neck and dipstick bell crank for transmission to carbs I will be looking for the oil lines. If I am missing anything please give me your expertise. A picture or oil lines diagram will be helpful. The first thing i would like to do is bench test it. As always, all advices are welcome and appreciated Thanks Paul Motor mount, tach or tach adaptor, oil pressure and temp gauge, heat block off tins, clutch/flywheel - maybe. heavier rear springs - possibly. |
Aug 19 2013, 09:03 PM
sorry, double post
914itis |
Aug 19 2013, 09:09 PM
Got the bulkhead motor mount with all hardware.
My current oil temp gauge Will not work ? Who sells the tach adapters? Clutch / flywheel? The flywheel is currently in there (oops! I think) do I need a different one? |
914itis |
Aug 19 2013, 09:15 PM
914itis |
Aug 21 2013, 08:26 PM
I took a good look at the motor again today, flywheel clutch and pressure plate are All there. They all seem to be in great shape.
I am missing every oil line. Does anyone have a diagram of the oil lines from motor to cooler then oil tank and returns? Do I need to cut ant holes to install the stock oil tank? I am sure this is just the beginning if the questions. Thanks |
Aug 21 2013, 08:38 PM
I took a good look at the motor again today, flywheel clutch and pressure plate are All there. They all seem to be in great shape. I am missing every oil line. Does anyone have a diagram of the oil lines from motor to cooler then oil tank and returns? Do I need to cut ant holes to install the stock oil tank? I am sure this is just the beginning if the questions. Thanks Search - there are many posts about oil lines and cutting the oil tank area. Read up on all the conversion threads and you'll be ready. PET should also show all the parts. |
914itis |
Aug 27 2013, 06:08 PM
8/27
I have located all the parts, Muffler and gauges arrived today. I wanted to go with the EVO, but I got a great deal on this from a member here. Attached thumbnail(s) |
Aug 27 2013, 07:13 PM
Yes, you need to cut holes for the tank.
If you get one from Patrick motors ports, I bet they will have a diagram for you. |
914itis |
Sep 3 2013, 09:29 PM
914itis |
Sep 3 2013, 09:32 PM
Sheet metal / tins
914itis |
Sep 3 2013, 09:36 PM
914itis |
Sep 22 2013, 10:07 AM
September update
Removed all fan and pulley for cleanup and powder coated. I built a bench to elevate the motor Installed Headers Installed Triad Muffler checked compression (all between 180-184) How wired engine for bench start Hot wire thread Attached image(s) |
Luke M |
Sep 22 2013, 10:23 AM
Senior Member Group: Members Posts: 1,377 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
You may want to install or not run the engine too long with that right rear tin missing.
914itis |
Sep 22 2013, 10:25 AM
Lo-Fi Version | Time is now: 8th June 2024 - 06:36 AM |
