Paul's stock six conversion |
914itis |
Sep 29 2013, 08:18 PM
I removed the 2.0 on preparation for the six,
I rwmoved the proportionimg valve and replaced it with a T Place the bulkhead in place. Next, I will be drilling and welding. Attached image(s) |
Kraftwerk |
Sep 29 2013, 10:26 PM
Member Group: Members Posts: 195 Joined: 6-September 07 From: Bbbbbrroooklynnn Member No.: 8,085 |
Paul,
Looks like another fun project. I have my car on the road again. jt |
Justinp71 |
Sep 29 2013, 10:29 PM
Senior Member Group: Members Posts: 1,584 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
914itis |
Sep 29 2013, 11:56 PM
bcheney |
Sep 30 2013, 06:26 AM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
All the best with your conversion. I completed mine last year. Have an original 914/6 Case rebuilt with 2.2 PC's, E cams, larger valves, weber 40 IDA 3C1's, MSD, stock distributor with points, headers and Leistritz sport muffler. It's a lot of fun to drive! You can see my build thread (bcheney six conversion). |
barefoot |
Sep 30 2013, 08:36 AM
Senior Member Group: Members Posts: 1,281 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
914itis |
Sep 30 2013, 08:46 AM
The bulkhead motor mount will not fit with the portioning valve.
In addition, I was told that using a T improves the rear braking system. |
Jeffs9146 |
Sep 30 2013, 10:49 AM
The bulkhead motor mount will not fit with the portioning valve. In addition, I was told that using a T improves the rear braking system. Or you can remove the late valve and lines and replace them with the early ones!! Thats what I did! Attached thumbnail(s) |
Kraftwerk |
Sep 30 2013, 09:20 PM
Paul,
Multiple little things.. runs better than ever now. Love it. How is that 2.0 engine, is it looking for a good home? Seems like your projects keep on keeping on! |
914itis |
Sep 30 2013, 10:15 PM
JT,
The 2.0 is great, good compression, no leaks no issues. I would like to keep it but I have no room. I am still debating, It is plug and play> If you are interested, We can talk. |
ConeDodger |
Sep 30 2013, 10:19 PM
Apex killer! Group: Members Posts: 23,612 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I removed the 2.0 on preparation for the six, I rwmoved the proportionimg valve and replaced it with a T Place the bulkhead in place. Next, I will be drilling and welding. Ooooooo! Don't let Eric see that! (IMG:style_emoticons/default/sad.gif) |
914itis |
Sep 30 2013, 10:31 PM
914itis |
Sep 30 2013, 10:39 PM
Spent a few hours today, I managed to cut and install the oil tank> was a bit easier than I anticipated.
Jeffs9146 |
Sep 30 2013, 10:43 PM
Don't forget to attach the bottom oil line before bolting it in! It can't be done after installation! (IMG:style_emoticons/default/beerchug.gif)
914itis |
Sep 30 2013, 10:59 PM
oops! I didn't (IMG:style_emoticons/default/headbang.gif)
914itis |
Sep 30 2013, 11:02 PM
Jeffs9146 |
Oct 1 2013, 06:37 AM
914itis |
Oct 1 2013, 06:41 AM
I need a picture showing the routing for the top oil line to the cooler. Do you have an external cooler or are you asking for the line that runs to the stock cooler? The line to the stock cooler is the bottom one that you didn't install! Correction. I meant the one from the block to the tank. Thanks. |
BKLA |
Oct 1 2013, 01:33 PM
Really old member Group: Members Posts: 1,253 Joined: 14-August 05 From: OR Member No.: 4,590 Region Association: Pacific Northwest |
Paul -
Pelican has images.... not entirely accurate for a -6 though. here's an image from the porsche catalog. free download from porsche... http://www.porsche.com/all/media/pdf/origi...914_KATALOG.pdf Hope that helps! |
SLITS |
Oct 1 2013, 02:51 PM
After you pull the tank again to install the first section of the suction hose, angle it very slightly towards the inner wheelhouse or it will interfere with the rocker panel.
There's a thread about making the hook to weld to support the two piece line. |
Lo-Fi Version | Time is now: 8th June 2024 - 06:35 AM |
